| Seagate ST3000DM001 Weird Rom http://forum.hddguru.com/viewtopic.php?f=10&t=38265 |
Page 1 of 1 |
| Author: | DRUG [ March 29th, 2019, 13:53 ] |
| Post subject: | Seagate ST3000DM001 Weird Rom |
Hi guys, I've been having some troubles with a drive and I was looking at the rom and found something strange (to me, as someone who isn't used to read roms) Here are some screenshots, can someone confirm either this is normal or not? http://imgur.com/a/ykFqe6M http://imgur.com/a/7MFq5du Thanks |
| Author: | digisupport [ March 29th, 2019, 14:08 ] |
| Post subject: | Re: Seagate ST3000DM001 Weird Rom |
Looks normal to me |
| Author: | MindMergepk [ March 30th, 2019, 4:25 ] |
what is the drive behavior on power up? |
| Author: | fzabkar [ March 30th, 2019, 4:43 ] |
I've examined numerous ROMs and I do recall seeing those same text strings. http://www.hddoracle.com/viewtopic.php?f=59&t=2173&p=14535&hilit=hrk#p14535 |
| Author: | DRUG [ March 31st, 2019, 17:37 ] |
MindMergepk wrote: what is the drive behavior on power up? The drive powers up, clicks a bit and stops clicking, board gets really hot tho. |
| Author: | digisupport [ April 1st, 2019, 5:02 ] |
Those strings are present in a Granada ROM, nothing unusual there. Personally i would take a look at the heads under microscope, will most likely tell you what you are dealing with. If none of the heads are dirty, maybe terminal can give you hint about whats going on. |
