 Post subject: Transferring OS to new bigger SSD
PostPosted: July 1st, 2019, 9:52
Hi everyone
My windows 10 system currently uses a 128gb ssd. I have just bought a 480gb ssd and woudl like to transfer my system and files over to the new ssd.
What is the easiest way to do this with a Windows 10 system? Which program should I use and what steps do I take? I would prefer not to have to install Windows 10 from scratch.
Thanks Peter
 Post subject: Re: Transferring OS to new bigger SSD
PostPosted: July 1st, 2019, 19:20
Search for "SSD Data Migration" software.
PostPosted: July 2nd, 2019, 1:43
You can try Acronis True image 2017 https://forum.acronis.com/forum/acronis ... s-directly
Boot from CD
select acronis true image
in GUI from Menu select Tools & Utilities
Clone disk
First select your source drive
then destination (your new drive)
just follow wizard
works 100%
PostPosted: July 2nd, 2019, 2:57
Don’t forget to backup your important data before doing this!
PostPosted: July 2nd, 2019, 3:13
What happens tyhough when you take a 120gb ssd image and use these programs to copy the image to a 480gb ssd. What happens to the other 3560Gb? Is thsi just free s[ace that will need to be partitioned separately?
cheers Peter
PostPosted: July 2nd, 2019, 3:42
program can manage to adjust the size of destination drive
if you clone to empty destination drive process is safe, because you can see only source and then on destination select empty drive
PostPosted: July 2nd, 2019, 3:45
I use Minitool Partition Wizard. It has a clone HDD feature, and it's very graphic, so the chance of error selecting source and donor, I believe it's low.
ACELab partner
PostPosted: July 2nd, 2019, 4:17
like in carpentry where you measure twice and cut once... check settings/drives etc twice, click OK once
the amount of times people have cloned their new drive to their old one beggars belief
