| ADATA S510 Firmware Fail http://forum.hddguru.com/viewtopic.php?f=10&t=38379 |
Page 1 of 1 |
| Author: | fzabkar [ May 4th, 2019, 16:59 ] |
| Post subject: | Re: ADATA S510 Firmware Fail |
If you don't need the data … http://forum.ru-board.com/topic.cgi?forum=84&topic=5360 |
| Author: | erebus [ May 5th, 2019, 7:18 ] |
My Russian is unfortunately too bad to read it The Data on The SSD is not needed. |
| Author: | fzabkar [ May 5th, 2019, 17:23 ] |
Use Google's translator: https://translate.google.com/translate?hl=&sl=ru&tl=de&u=http%3A%2F%2Fforum.ru-board.com%2Ftopic.cgi%3Fforum%3D84%26topic%3D5360 Restoring SSDs on a SandForce SF-2XXX controller (Video instruction): https://www.youtube.com/watch?v=vSCr3UzyzhM |
| Author: | erebus [ May 8th, 2019, 15:15 ] |
thx for you help. I looked at the list and have 2 possible configurations. but which is the right one? Attachment: 2019-05-08 21_05_50-.png [ 5.13 KiB | Viewed 11485 times ] Attachment: 2019-05-08 21_07_01-.png [ 5.98 KiB | Viewed 11485 times ] |
| Author: | fzabkar [ May 8th, 2019, 16:34 ] |
You can choose either. The lower user capacity will have correspondingly more overprovisioned space, resulting in higher performance. https://www.seagate.com/au/en/tech-insights/ssd-over-provisioning-benefits-master-ti/ |
| Author: | erebus [ May 8th, 2019, 19:12 ] |
I can Say That... The SSD is alive again! Thanks alot |
| Author: | erebus [ May 10th, 2019, 17:41 ] |
Does anyone know if this SSD has a temperature sensor? I could not locate any on the board. |
| Author: | fzabkar [ May 10th, 2019, 18:24 ] |
erebus wrote: Does anyone know if this SSD has a temperature sensor? I don't recognise any discrete temperature sensor IC. What is the marking on U73? Is it "F2C"? Is there a temperature attribute in the SMART report? |
| Author: | erebus [ May 10th, 2019, 19:30 ] |
The Marking is 14BBJ. Smart say Temp. not Supportet and SSD Toolbox say Temp over 60000 Grad |
| Author: | fzabkar [ May 10th, 2019, 19:44 ] |
erebus wrote: The Marking is 14BBJ. That's U72. MP6400DJ-01, adjustable Programmable-Delay Supervisory Circuit, marking 4Bxx, TSOT23-6: http://www.mouser.com/ds/2/277/MP6400_r1.1-371744.pdf |
| Author: | erebus [ May 13th, 2019, 16:06 ] |
I think this ssd has no temperature sensor. |
