| Can't burn Windows 10 ISO to USB 2.0 http://forum.hddguru.com/viewtopic.php?f=10&t=38390 |
Page 1 of 1 |
| Author: | pantofle [ May 9th, 2019, 22:03 ] |
| Post subject: | Can't burn Windows 10 ISO to USB 2.0 |
I am trying to make a bootable USB to install Windows 10 on a new built PC with Windows Media Creation Tool. Follow the steps and everything goes fine as expected. However, it comes to an error after waiting about 30 minutes. Say There is an error to install Windows 10 on that USB stick. It is 8G Kingston |
| Author: | HaQue [ May 10th, 2019, 6:49 ] |
| Post subject: | Re: Can't burn Windows 10 ISO to USB 2.0 |
try with a different USB. are you trying to do it "online" or are all files needed downloaded locally? If you can download an ISO instead, I recommend using Rufus. |
| Author: | Ukaser [ May 12th, 2019, 21:22 ] |
Is the USB you're using new?it is best to prepare a new USB for burning Windows 10 iSO,and for the iSO,Microsoft website will provide you. |
| Author: | HaQue [ May 13th, 2019, 0:36 ] |
Ukaser wrote: Is the USB you're using new?it is best to prepare a new USB for burning Windows 10 iSO,and for the iSO,Microsoft website will provide you. I disagree. There are plenty of ways to check a USB for integrity, just need one that is ok and enough capacity. Also need to make you create the correct type of bootdisk, and the device you are trying to boot has correct settings in BIOS in regard to UEFI, Legacy, secure boot etc.. he already is getting the tool from Microsoft. Sometimes USBs with CD emulated partitions or other security technologies create problems, but usually you see that before process starts. |
| Author: | pantofle [ May 13th, 2019, 22:43 ] |
HaQue wrote: try with a different USB. are you trying to do it "online" or are all files needed downloaded locally? If you can download an ISO instead, I recommend using Rufus. I don't have the ISO file. Media Creation Tool claims it will download the ISO and burn it automatically. When I go to Windows 10 download page: https://www.microsoft.com/en-au/softwar ... /windows10 The download link directly goes to Media Creation Tool |
