Best solution to clean/grind microSD card????
May 29th, 2019, 12:19
I have several cases with microSD cards not working. What is the best solution to remove the first layer of the microSD card (grinding process)? Any suggestions? I use sand paper but it is a really hard work. Does someone try laser? Do you recommend it? What is the best approach?
Re: Best solution to clean/grind microSD card????
May 29th, 2019, 12:33
Fiberglass pen or laser, if you can afford it.
May 30th, 2019, 8:43
+1 for fiberglass pen
May 31st, 2019, 17:47
+1 for fiberglass pen as well.
it will be just as labour intensive as the sandpaper (if not slightly more), but there's virtually no risk of grinding too deep and sanding off the first layer of contacts on the microSD.
June 3rd, 2019, 6:04
Does someone have used laser? Is it easy to use to grind the microSD as show in youtube video?
June 3rd, 2019, 9:40
digisupport wrote:+1 for fiberglass pen
Giroot wrote:+1 for fiberglass pen as well.
What brand of fiberglass pen you use or you recommend ?
June 3rd, 2019, 9:49
The K-Tool International KTI (KTI-70550) Sanding Pen works well. Not much effort required. There are some that are softer but you will never finish the job :)
