 Post subject: Verbatim SD 4GB
PostPosted: May 23rd, 2019, 10:14
I try to recover data from SD card 4GB.
According to Ace its SDHC type4
with spider board when I check pin it report's that everything is ok, but wen I read id I receive errors
I receive following errors
Bus 8 bit
ResetFail. Ignore RST Fail is recommended
Bus 18 bit jedec
ID Uncorrect
Bus 16 bit ONFI
Any suggestion.
Learning purpose
Thank you
 Post subject: Re: Verbatim SD 4GB
PostPosted: May 23rd, 2019, 14:17
R/B is wrong connected or in wrong place... use software method as suggested so in Parametrs check Ignore reset status
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
PostPosted: May 23rd, 2019, 14:27
Thank you very much Boguslaw
