HDD GURU FORUMS
http://forum.hddguru.com/
Verbatim SD 4GB
http://forum.hddguru.com/viewtopic.php?f=10&t=38443
Page 1 of 1
Author:  jerovsek [ May 23rd, 2019, 10:14 ]
Post subject:  Verbatim SD 4GB
I try to recover data from SD card 4GB.
According to Ace its SDHC type4
with spider board when I check pin it report's that everything is ok, but wen I read id I receive errors
I receive following errors
Bus 8 bit
ResetFail. Ignore RST Fail is recommended
Bus 18 bit jedec
ID Uncorrect
Bus 16 bit ONFI
Any suggestion.
Learning purpose
Thank you
Author:  Bolo [ May 23rd, 2019, 14:17 ]
Post subject:  Re: Verbatim SD 4GB
R/B is wrong connected or in wrong place... use software method as suggested so in Parametrs check Ignore reset status
Author:  jerovsek [ May 23rd, 2019, 14:27 ]
Thank you very much Boguslaw
http://www.phpbb.com/
