| SD Card files appeared after format. http://forum.hddguru.com/viewtopic.php?f=10&t=38485 |
Page 1 of 1 |
| Author: | hack3rcon [ June 8th, 2019, 6:31 ] |
| Post subject: | SD Card files appeared after format. |
Hello. I have a SD Card and when I format it then all files appeared on it again: Code: $ sudo mkfs.ntfs /dev/sdc1 Cluster size has been automatically set to 4096 bytes. Initializing device with zeroes: 100% - Done. Creating NTFS volume structures. mkntfs completed successfully. Have a nice day. And: Code: $ sudo mkfs.ext4 /dev/sdc1 mke2fs 1.42.12 (29-Aug-2014) /dev/sdc1 contains a vfat file system Proceed anyway? (y,n) y Creating filesystem with 3910400 4k blocks and 979200 inodes Filesystem UUID: 97b8db17-e6f5-415f-b1c4-e108cc135d07 Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208 Allocating group tables: done Writing inode tables: done Creating journal (32768 blocks): done Writing superblocks and filesystem accounting information: done And: Code: $ sudo dd if=/dev/null of=/dev/sdc1 bs=512 0+0 records in 0+0 records out 0 bytes (0 B) copied, 0.000149921 s, 0.0 kB/s I used some tools like "EaseUS" and "AOMEI" on Windows OS too but problem exist. Any idea? Thank you. |
| Author: | hack3rcon [ June 9th, 2019, 1:58 ] |
| Post subject: | Re: SD Card files appeared after format. |
Any idea? |
| Author: | einstein9 [ June 9th, 2019, 6:34 ] |
hack3rcon wrote: Any idea? Controller gone crazy (OS level) If you want to (factory) format it, then you may search for the proper tool based on its Controller you may start from here: www.usbdev.ru/files |
| Author: | hack3rcon [ June 9th, 2019, 16:33 ] |
How can I find its controller model? The company is "Integral". |
| Author: | fzabkar [ June 9th, 2019, 18:03 ] |
hack3rcon wrote: How can I find its controller model? ChipGenius ? |
| Author: | hack3rcon [ June 10th, 2019, 1:38 ] |
fzabkar wrote: hack3rcon wrote: How can I find its controller model? ChipGenius ? How about Linux? |
