| Cloning and disk signature collisions http://forum.hddguru.com/viewtopic.php?f=10&t=38515 |
Page 1 of 1 |
| Author: | snifferpro [ June 17th, 2019, 7:47 ] |
| Post subject: | Cloning and disk signature collisions |
I do both a clone of my C drive and an image backup. On a couple of occasions I have had to boot the newly cloned drive and forgot to remove the original source drive. This gives me Disk Signature collision which I think I understand. What I'd like to do is change the disk signature of the original source drive which is a GPT SSD. All the articles I've found on the net seem to suggest using diakpart which I have no problems using. Where I do have an issue is with determining how to provide a new disk signature. What is the format of the GUID GPT disk signature? How do I create a new disk signature? Is it just a string of random numbers? If diskpart doesn't like the format or the actual id how do I create one that diskpart will accept. Thanks |
| Author: | fzabkar [ June 17th, 2019, 20:03 ] |
| Post subject: | Re: Cloning and disk signature collisions |
snifferpro wrote: How do I create a new disk signature? Is it just a string of random numbers? What is Disk Signature Collision? How to fix Disk Signature Collision problem on Windows? https://www.thewindowsclub.com/disk-signature-collision-problem The signature consists of 8 random hexadecimal digits (4 bytes) in sector 0. An Examination of the Windows 7, 8/8.1 or 10 MBR ( Master Boot Record ): https://thestarman.pcministry.com/asm/mbr/W7MBR.htm An Examination of The Microsoft Windows 7 and 8 GPT 'Protective' MBR and EFI Partitions: https://thestarman.pcministry.com/asm/mbr/GPT.htm Quote: These four bytes from offsets 1B8h through 1BBh are called the Windows Disk Signature or NT Drive Serial Number. You can examine sector 0 with a disc editor such as DMDE: https://dmde.com/ |
| Author: | snifferpro [ June 18th, 2019, 6:12 ] |
fzabkar - Thank you very much for your answer and links. It definitely helps clear things up for me. |
