Newbie questions
http://forum.hddguru.com/viewtopic.php?f=10&t=38541
Author:  jonbang [ June 24th, 2019, 13:04 ]
Post subject:  Newbie questions
Hello. I have a samsung tablet TAB 2,7, the modelname is gt-p3110. Its a tab i found, and iss just using for the practice.
But the chip listed over is what i believe is the eMMC-disk. I cannot find anything to identify the controller. There is another chip on the PCD called: Samsung k3pe7e700x-xgci wich i found is RAM. I used the pc3000 flash adatper called BGA-152, and i belive this is the wrong adapter. What adapter will be the right for this? I will order more adapters, i have right now only the basic flash-package. But how to identify the controller for this? Is that integrated with the eMMC-disk? And will it come visible when i use the rigth adapter?
And is there som index what adapters to use with the different chips, or is that relative logic? I mean, if it dont fit, thats logic, but when the chip is to big for the adapter...?
Author:  Amarbir[CDR-Labs] [ June 24th, 2019, 13:27 ]
Post subject:  Re: Newbie questions
Well,
You Need To Buy UFI Box or Easy JTAG And Few Adapters And Voila Job Done ,Incase You Have Un Encrypted EMMC,For Encrypted EMMC i Am Not To Knowledgeable As i Do More Of Mechanical Drives Data Recovery
Author:  HaQue [ June 25th, 2019, 0:40 ]
how about listing the part number of the chip you are interested in, or a photo of boh sides of chip. there is nothing in your question that can be answered well.
