Re: SmartNAND recovery?
Posted: July 4th, 2019, 2:05
HaQue wrote:I doubt that that comes into play as normally when strange devices are hooked up to flash drives, the NAND is wired to directly. and whatever the device is (eMMC, SD, MicroSD) does not use its internal controller, but uses the one on the flash drive PCB.
I don't understand your response. All I was suggesting was that the AppoTech controller would not (or should not) be able to write to the ECC byte(s) in the SA (because the BENAND generates the ECC), in which case the XOR algorithm would be a little more complex (data + SA - ECC), or it could be that AppoTech avoids writing to the SA altogether.
