| Is data recoverable from this SSD drive? http://forum.hddguru.com/viewtopic.php?f=10&t=38625 |
Page 1 of 1 |
| Author: | magnusivarsson [ July 10th, 2019, 14:22 ] |
| Post subject: | Is data recoverable from this SSD drive? |
Hello! I threw away old electronics at the recycling station some time ago and just wanted out of curiosity to know if someone else can recover the data from it. I used Secure Erase to securely format the SSD drive, and then I also physically destroyed it by simply cutting it down to a lot of pieces, meaning cutting of the flash memorys as well and cutting them down to pieces, and cutting the entire "surface" of it down to pieces. Is it safe to say this can not be recovered now? Highly appreciate the reply. |
| Author: | HaQue [ July 10th, 2019, 19:27 ] |
| Post subject: | Re: Is data recoverable from this SSD drive? |
There needs to be a "This is a load of crap" field after using the report button |
| Author: | ddrecovery [ July 10th, 2019, 19:32 ] |
HaQue wrote: There needs to be a "This is a load of crap" field after using the report button Oh Yes https://forum.hddguru.com/viewtopic.php?f=1&t=38624 |
| Author: | Dananjaya [ July 10th, 2019, 23:11 ] |
canbe recovered |
