 Post subject: Power Failure M2 Sata Toshiba SSD kbg30zmv256g
PostPosted: July 20th, 2019, 5:48
I have Toshiba 256GB M2 Toshiba SSD kbg30zmv256g.
The hdd is not detected. Behavior like NO hdd is connected with pc3k or like the power failure hdd.
I have tried to found faulty components and created the output voltage diagram.
Attached the image of m2 sata. How to recover the data?
Thanks,
File comment: Voltage output Toshiba SSD kbg30zmv256g.
 Post subject: Re: Power Failure M2 Sata Toshiba SSD kbg30zmv256g
PostPosted: July 20th, 2019, 7:32
Google tells me that this is an NVMe SSD. Does PC3000 support NVMe now?
PostPosted: July 20th, 2019, 10:16
I have m2 to sata converter.
So I have used the sata converter and checked on pc3000. but not shown any led like busy, drd, dsc.
also I have used working m2 drive with this connector. it detects and shows drd, dsc enable.
Thanks,
PostPosted: July 20th, 2019, 14:18
thinclient wrote:
I have m2 to sata
For PCIe? Really? :-)
PostPosted: July 20th, 2019, 14:30
pcimage wrote:
thinclient wrote:
I have m2 to sata
+1
PostPosted: July 20th, 2019, 17:11
Pretty sure you don’t
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: July 20th, 2019, 18:35
Could we see it?
PostPosted: July 21st, 2019, 9:26
This adapter is likely not NVMe compatible and the working/test SSD isn't an NVMe SSD either.
Can you confirm?
PostPosted: July 21st, 2019, 10:40
Can you confirm?
+1000000
There is No NVMe to SATA adapter yet... not AFAIK..
PostPosted: July 24th, 2019, 0:24
yes You are right.
I have B+M key socket 2(sata) m2 NGFF SSD converter. Due to same type of pin slot I have checked the NVMe on this adapter.
Now I have used the nvme supported motherboard. It detects in bios. but not found in windows10. Device manager shows dirver missing "Standard NVMe controller"
Thanks.
PostPosted: July 24th, 2019, 2:28
thinclient wrote:
yes You are right.
Thanks.
So you have updated BIOS and installed newest drivers for mainboard?
What happens now?
PostPosted: July 24th, 2019, 5:25
thinclient wrote:
yes You are right.
Thanks.
coz its controller is gone crazy, same scenario with SSD with BSY
chip-off is a must with high pro. tools (VNR helps a lot here)
PostPosted: July 25th, 2019, 8:25
HaQue wrote:
thinclient wrote:
yes You are right.
Thanks.
What happens now?
Toshiba online site shows it use the microsoft default nvme driver. no need of any extra driver.
I have checked the system with other working adata drive. it detected in windows.
Searching solution. I doubt in the Toshiba nvme controller. but no separate controller found in this drive.
PostPosted: July 25th, 2019, 8:26
einstein9 wrote:
thinclient wrote:
yes You are right.
Thanks.
yes +1
PostPosted: July 25th, 2019, 10:55
I don't know.. what is the controller? Is there any chips on the other side? I don't think so.. so a single chip? If so must be a BGA SSD, and I am unsure of if these have been recovered by any tools yet.
The XG5 is also the first SSD from Toshiba to leverage the company’s 64-layer BiCS 3D flash memory (TLC) which delivers the highest layer count in the market.
Newer XG6-P have 96layer BiCS Flash! Are these chips supported in our flash tools?
I would be interested in a picture of the drive without the sticker (even though I think this picture is not of the real patient, but a stock picture from ebay)
BTW, it says NVMe right on the label...
Also, in regards to the label.. does "R-REM-TMZ-KBG3AZMV512G" mean that this is a refurbished 512G SED drive? I think the "0" in "kbg30zmv256g" means not SED and the "A" in "KBG3AZMV512G" denotes a SED drive
PostPosted: July 25th, 2019, 15:51
I think that is a certification code. I see these same kinds of certs on HDDs. AIUI, one member of a particular model series is tested and certified, and this code is then applied to the other members of the same family.
https://fccid.io/R-REM-TMZ-KBG3AZMV512G
An KCC / MSIP R ID is the authorization ID assigned by the Korean Communications Commission to identify wireless products in the Korean market. The R assigns application ID numbers and Authorization number to approved products. The SOLID STATE DRIVE, manufactured by Toshiba Memory Corporation and sold by Toshiba Memory Corporation has an Authorization Number of R-REM-TMZ-KBG3AZMV512G and was approved on 2018-02-28 under application number 201817210000045827.
PostPosted: July 25th, 2019, 19:52
Makes sense, Thanks. I guess there isn't a whole lot of difference between the different drives.
Certification must be a real Bug Bear for drive vendors :(
PostPosted: July 25th, 2019, 22:57
Here are two drives with the same cert code, but different covers and model numbers, even though they are supposed to be identical:
https://forums.tomshardware.com/threads/hdd-toshiba-mq04abd200-vs-toshiba-l200-hdwl120xzsta.3503546/
PostPosted: September 23rd, 2019, 11:23
Hello all,
I've just received one of these this afternoon. The BGA chip is marked with:
Toshiba KBG30ZPZ256G
18109AE TWN SG1386
It looks like it is the BG3 64-layer package. Specs at: https://business.toshiba-memory.com/en- ... d/bg3.html
The failed SSD I have in gets a hot BGA chip when powered.
John
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
PostPosted: October 14th, 2019, 0:53
Hi Guy's
I Also Require M2 To Sata Converter. Please Help And Share the link.
Bikram
