Power Failure M2 Sata Toshiba SSD kbg30zmv256g
http://forum.hddguru.com/viewtopic.php?f=10&t=38668
Page 1 of 2
Author:  thinclient [ July 20th, 2019, 5:48 ]
Post subject:  Power Failure M2 Sata Toshiba SSD kbg30zmv256g
I have Toshiba 256GB M2 Toshiba SSD kbg30zmv256g.
The hdd is not detected. Behavior like NO hdd is connected with pc3k or like the power failure hdd.
I have tried to found faulty components and created the output voltage diagram.
Attached the image of m2 sata. How to recover the data?
Thanks,
File comment: Voltage output Toshiba SSD kbg30zmv256g.
Author:  fzabkar [ July 20th, 2019, 7:32 ]
Post subject:  Re: Power Failure M2 Sata Toshiba SSD kbg30zmv256g
Google tells me that this is an NVMe SSD. Does PC3000 support NVMe now?
Author:  thinclient [ July 20th, 2019, 10:16 ]
I have m2 to sata converter.
So I have used the sata converter and checked on pc3000. but not shown any led like busy, drd, dsc.
also I have used working m2 drive with this connector. it detects and shows drd, dsc enable.
Thanks,
Author:  pcimage [ July 20th, 2019, 14:18 ]
thinclient wrote:
I have m2 to sata
For PCIe? Really? :-)
Author:  ddrecovery [ July 20th, 2019, 14:30 ]
pcimage wrote:
thinclient wrote:
I have m2 to sata
+1
Author:  digisupport [ July 20th, 2019, 17:11 ]
Pretty sure you don’t
Author:  fzabkar [ July 20th, 2019, 18:35 ]
Could we see it?
Author:  labtech [ July 21st, 2019, 9:26 ]
This adapter is likely not NVMe compatible and the working/test SSD isn't an NVMe SSD either.
Can you confirm?
Author:  einstein9 [ July 21st, 2019, 10:40 ]
Can you confirm?
+1000000
There is No NVMe to SATA adapter yet... not AFAIK..
Author:  thinclient [ July 24th, 2019, 0:24 ]
yes You are right.
I have B+M key socket 2(sata) m2 NGFF SSD converter. Due to same type of pin slot I have checked the NVMe on this adapter.
Now I have used the nvme supported motherboard. It detects in bios. but not found in windows10. Device manager shows dirver missing "Standard NVMe controller"
Thanks.
Author:  HaQue [ July 24th, 2019, 2:28 ]
thinclient wrote:
yes You are right.
Thanks.
So you have updated BIOS and installed newest drivers for mainboard?
What happens now?
Author:  einstein9 [ July 24th, 2019, 5:25 ]
thinclient wrote:
yes You are right.
Thanks.
coz its controller is gone crazy, same scenario with SSD with BSY
chip-off is a must with high pro. tools (VNR helps a lot here)
Author:  thinclient [ July 25th, 2019, 8:25 ]
HaQue wrote:
thinclient wrote:
yes You are right.
Thanks.
What happens now?
Toshiba online site shows it use the microsoft default nvme driver. no need of any extra driver.
I have checked the system with other working adata drive. it detected in windows.
Searching solution. I doubt in the Toshiba nvme controller. but no separate controller found in this drive.
Author:  thinclient [ July 25th, 2019, 8:26 ]
einstein9 wrote:
thinclient wrote:
yes You are right.
Thanks.
yes +1
Author:  HaQue [ July 25th, 2019, 10:55 ]
I don't know.. what is the controller? Is there any chips on the other side? I don't think so.. so a single chip? If so must be a BGA SSD, and I am unsure of if these have been recovered by any tools yet.
The XG5 is also the first SSD from Toshiba to leverage the company’s 64-layer BiCS 3D flash memory (TLC) which delivers the highest layer count in the market.
Newer XG6-P have 96layer BiCS Flash! Are these chips supported in our flash tools?
I would be interested in a picture of the drive without the sticker (even though I think this picture is not of the real patient, but a stock picture from ebay)
BTW, it says NVMe right on the label...
Also, in regards to the label.. does "R-REM-TMZ-KBG3AZMV512G" mean that this is a refurbished 512G SED drive? I think the "0" in "kbg30zmv256g" means not SED and the "A" in "KBG3AZMV512G" denotes a SED drive
Author:  fzabkar [ July 25th, 2019, 15:51 ]
I think that is a certification code. I see these same kinds of certs on HDDs. AIUI, one member of a particular model series is tested and certified, and this code is then applied to the other members of the same family.
https://fccid.io/R-REM-TMZ-KBG3AZMV512G
An KCC / MSIP R ID is the authorization ID assigned by the Korean Communications Commission to identify wireless products in the Korean market. The R assigns application ID numbers and Authorization number to approved products. The SOLID STATE DRIVE, manufactured by Toshiba Memory Corporation and sold by Toshiba Memory Corporation has an Authorization Number of R-REM-TMZ-KBG3AZMV512G and was approved on 2018-02-28 under application number 201817210000045827.
Author:  HaQue [ July 25th, 2019, 19:52 ]
Makes sense, Thanks. I guess there isn't a whole lot of difference between the different drives.
Certification must be a real Bug Bear for drive vendors :(
Author:  fzabkar [ July 25th, 2019, 22:57 ]
Here are two drives with the same cert code, but different covers and model numbers, even though they are supposed to be identical:
https://forums.tomshardware.com/threads/hdd-toshiba-mq04abd200-vs-toshiba-l200-hdwl120xzsta.3503546/
Author:  cheadledatarecovery [ September 23rd, 2019, 11:23 ]
Hello all,
I've just received one of these this afternoon. The BGA chip is marked with:
Toshiba KBG30ZPZ256G
18109AE TWN SG1386
It looks like it is the BG3 64-layer package. Specs at: https://business.toshiba-memory.com/en- ... d/bg3.html
The failed SSD I have in gets a hot BGA chip when powered.
John
Author:  bikram [ October 14th, 2019, 0:53 ]
Hi Guy's
I Also Require M2 To Sata Converter. Please Help And Share the link.
Bikram
Page 1 of 2 All times are UTC - 5 hours [ DST ]
