Read flash memory directly from chip
http://forum.hddguru.com/viewtopic.php?f=10&t=38761
Author:  maddin [ August 15th, 2019, 11:28 ]
Post subject:  Read flash memory directly from chip
I would want to ask what equipment you use for recovering data from a momory-card, USB-pendrive, etc. in case they cant be recogniced by the system.
I found for exampe the RuSolut equipment. Are there other brands / tools / software which are good for that task as well?
Exist there also a cheaper alternative like MRT / DFL for PC-3000?
Thanks for your tips,
Martin
Author:  melvin [ August 15th, 2019, 12:44 ]
Post subject:  Re: Read flash memory directly from chip
As you mentioned: Rusolut, also PC3k flash, Flash extractor. Each is different, has it's advantages and solutions.
