 Post subject: "LLF"-ing a SSD
PostPosted: August 27th, 2019, 12:42
I get and then sell lots of used HDDs and SSDs which I first "Low Level Format" with the HDD LLF Tool (https://hddguru.com/software/HDD-LLF-Lo ... rmat-Tool/), so that if someone would try and use a "home recovery tool" like Recuva, would not be able to recover any data from the old drives.
HDD LFF Tool works great for the HDDs. But is it fine for SSDs too? Or is it overkill? If it's overkill, what else should I use/do?
Thank you.
 Post subject: Re: "LLF"-ing a SSD
PostPosted: August 27th, 2019, 14:07
Most SSDs will erase in less than 20 seconds with a secure erase command.
PostPosted: August 27th, 2019, 15:15
And will it be possible, after the 20 second secure erase command, to recover any data from the SSD, with a "home recovery tool" like Recuva?
If not, which program should I use to secure erase various SSDs that I get and then sell? I'd like something equivalent to what HDD LLF Tool does to HDDs.
Thank you.
PostPosted: August 27th, 2019, 17:51
Most SSD's are Encrypted...
Issuing a Secure Erase Command to a SSD will typically change the encryption key..
Even without erasing all the NAND the data will effectively be destroyed.
Recover My Flash Drive
PostPosted: August 28th, 2019, 12:03
OK, so how do I do that, which program do I use, how do I issue a Secure Erase Command to a SSD?
Thank you.
PostPosted: August 28th, 2019, 14:43
good luck with preamently deleting all data..i got enough skill to recover and data what is secure deleted what was used..i can do it cuse i have some forsenics experience i learned from freind who worked as forsenic and also worked long very time ago at seagate..
PostPosted: August 29th, 2019, 10:00
I just want to erase them well enough so that a second-hand buyer won't be able to recover data with simple "home use" tools like Recuva.
So how should I go about it? Download the Samsung/Crucial/Kingston/whatever... proprietary SSD program and us it to Secure Erase the SSD?
Or is there an universal SSD erasing program I could use? Thanx.
PostPosted: August 29th, 2019, 10:46
good idea is to go to the vendor website and search their FAQs
better idea:
1. find a drive you want to erase for test
2. write a heap of .jpgs on there. choose small ones so when you do your test they would be easy to recover.
3. go to that SSD vendors website and search for method they recommend, or google how to erase a drive, then do it.
4. try to recover with recuva and any other tool you can grab.
5. you have your piece of mind, or you find method is flawed.
lather, rinse, repeat until you get results...
If you cant get the results you want, you now have something specific to ask on forums, and you can provide your trials and tribulations and get guidance.
if you don't test, you will never be satisfied.
