| MicroSD READ-ONLY behaviour in Android http://forum.hddguru.com/viewtopic.php?f=10&t=38889 |
Page 1 of 1 |
| Author: | einstein9 [ September 11th, 2019, 5:15 ] |
| Post subject: | MicroSD READ-ONLY behaviour in Android |
Hello guys,,, I was wondering if someone knows about this issue or had similar cases like this... MicroSD memory added to Android Mobile (Android 6+ & higher) and you use it for a while (Enabled Encryption or not its the same) when you pull it out and connect to windows you are able to READ its data but you CANNOT FORMAT/MODIFY it no matter what you do, it says Format done, but nothing changes... DATA remains the same (either Encrypted or not) anyone got similar to this scenario? Note: I came up with a result about this matter and wanted to verify with those who had similar cases... you may PM if don`t want to go public about it... thank you |
| Author: | HaQue [ September 11th, 2019, 6:27 ] |
| Post subject: | Re: MicroSD READ-ONLY behaviour in Android |
Is it a Kingston branded memory? or does this happen with different flash cards? |
| Author: | einstein9 [ September 11th, 2019, 7:25 ] |
HaQue wrote: Is it a Kingston branded memory? or does this happen with different flash cards? Any brand,,, I have more than 10 now for research, Sandisk, Kingston and some other unbranded too |
| Author: | HaQue [ September 11th, 2019, 8:19 ] |
is it the read only attribute on the actual partition? or were they exFAT and not really FAT32? this page https://forum.fairphone.com/t/sd-card-suddenly-switches-to-read-only-file-system/37570/6 is saying: Quote: I figured out that instead of rebooting one can unmount the SD card (Settings -> Storage -> Chose SD Card -> Eject -> Confirm) and then mount the card again, without removing it from the device. with a reply Quote: Thanks for the hint. Unmounting and re-mounting the SD card does indeed work. And is faster than a reboot. more info https://forum.fairphone.com/t/list-of-compatible-microsd-sdxc-cards-for-fp2/33672 |
| Author: | einstein9 [ September 11th, 2019, 9:04 ] |
@ HaQue PM Sent. |
| Author: | suricate.ch [ July 13th, 2022, 10:55 ] |
I have a FairPhone 2, stuck on Android logo after OS upgrade failure. I tried "wiping cache", doesn't help. Anyone knows a tool that can extract data ? |
| Author: | Arch Stanton [ July 15th, 2022, 9:47 ] |
Could TMP_WRITE_PROTECT bit be set? |
