HDD GURU FORUMS
http://forum.hddguru.com/
128GB Toshiba Marvel ( Apple NVME ) no ID
http://forum.hddguru.com/viewtopic.php?f=10&t=38896
Page 1 of 1
Author:  nicoalbrecht [ September 13th, 2019, 3:40 ]
Post subject:  128GB Toshiba Marvel ( Apple NVME ) no ID
Any advice what to try on a 128GB Toshiba Marvel from a macbook.
SSD doesn't id in
1. DDI NVME
2. PC3000 via usb enclosure
controller seems to warm up to about 50 degress but shows 0 lba via usb enclosure and doesn't show up at all in DDI. Controller doesn't get warm in DDI NVME add on.
Any input welcome.
Author:  fzabkar [ September 13th, 2019, 4:30 ]
Post subject:  Re: 128GB Toshiba Marvel ( Apple NVME ) no ID
Check the supply voltage at the edge connector. Also check the DEVSLP pin. That's the power on/off control pin.
If you post a hi-res photo of your PCB, I could identify the voltage test points.
http://www.phpbb.com/
