 Post subject: 128GB Toshiba Marvel ( Apple NVME ) no ID
PostPosted: September 13th, 2019, 3:40
Any advice what to try on a 128GB Toshiba Marvel from a macbook.
SSD doesn't id in
1. DDI NVME
2. PC3000 via usb enclosure
controller seems to warm up to about 50 degress but shows 0 lba via usb enclosure and doesn't show up at all in DDI. Controller doesn't get warm in DDI NVME add on.
Any input welcome.
 Post subject: Re: 128GB Toshiba Marvel ( Apple NVME ) no ID
PostPosted: September 13th, 2019, 4:30
Check the supply voltage at the edge connector. Also check the DEVSLP pin. That's the power on/off control pin.
If you post a hi-res photo of your PCB, I could identify the voltage test points.
Users browsing this forum: No registered users and 14 guests
