Page 1 of 1
USB 3.0 Connector Pinout
Posted: September 19th, 2019, 18:09
by jeremyb
I got this drive from another DR company and it has no USB 3.0/3.1 header, does anyone know which pads are for USB 2.0 D+ and D-
Re: USB 3.0 Connector Pinout
Posted: September 19th, 2019, 18:45
by fzabkar
Is this a trick question?
https://pinouts.ru/Slots/USB_pinout.shtmlThis layout would seem the most logical:
- USB3.0_Monolithic-Pinout_2.0_pads.png (619.41 KiB) Viewed 10222 times
Posted: September 19th, 2019, 19:46
by jeremyb
fzabkar wrote:Is this a trick question?
That was my first guess but it doesn't appear to work
Posted: September 19th, 2019, 20:16
by HaQue
so drive not working probably.
what are the 5 rectangular traces in the middle? some sort of signal interference mitigation or something?
looks like you may need to find a donor and use the 30 pads up top to find nand pinout. whats the drive?
Posted: September 19th, 2019, 20:29
by jeremyb
I think something is fubar w/ the controller, the 3.3v rail isn't outputting the proper voltage.. I'll check the passive components tomorrow...
Posted: September 20th, 2019, 3:37
by p_patryk
I think your pinout is right. Pad with 5V is cut out from two vias on the bottom from it. I guess it is the reason why you can't power up device.
Posted: September 20th, 2019, 15:47
by fzabkar
p_patryk wrote:I think your pinout is right. Pad with 5V is cut out from two vias on the bottom from it. I guess it is the reason why you can't power up device.
So it was a trick question. :-)
Posted: September 21st, 2019, 9:32
by HaQue
it is either cut, or there is still some black coating left on there where laser missed.
