| Kingston datatraveler 4GB G3 problem http://forum.hddguru.com/viewtopic.php?f=10&t=38988 |
Page 1 of 1 |
| Author: | Pak1 [ October 4th, 2019, 9:40 ] |
| Post subject: | Kingston datatraveler 4GB G3 problem |
Hi all, I've this pendrive with shorted controller. I need to recover data. The controller ic is: SSS 6691 H1-M6C J4803-580B 1044 The NAND chip is: Phison HVPF4F5 115T051LF-3S-1 Because I don't have a nand reader, I tought to replace the controller. Is this right way? If yes, the problem is to found a donor. Where I can search? Same pendrive is no longer available to buy on line. Thanks. Pak |
| Author: | arvika [ October 4th, 2019, 10:36 ] |
| Post subject: | Re: Kingston datatraveler 4GB G3 problem |
Usually it is hard to find matching donor, and it is risky for data. Best way is chip-off method. |
| Author: | Pak1 [ October 4th, 2019, 10:54 ] |
Thanks for your reply, arvika. In order to invest..., which tools do you suggest for chip-off method? |
| Author: | arvika [ October 4th, 2019, 11:17 ] |
For one case only? None. It not pay back. Better if you outsource the case. |
| Author: | pcimage [ October 5th, 2019, 4:55 ] |
arvika wrote: For one case only? None. It not pay back. Better if you outsource the case. +1 You’re looking at around $2100 for Soft Center reader and software licence, which is the best for this horrible controller. http://www.flash-extractor.com/shop/ Or probably $300 to have it recovered professionally. |
