 Post subject: [SSD] M.2 LITEON CV3-8D512-11 - DEAD BEEF
PostPosted: October 20th, 2019, 14:29
Drive is undetected, I tried shorting what I assume is the factory jumper.. same result..
I tried Freeze spray, nothing stands out as overheating..
I uploaded a high resolution photo below with a few measurements (click download on the top left to see the full image)... Not sure if its FTL corruption or physical damage.
https://recovermyflashdrivecom-my.share ... w?e=7f8H5l
@fzabkar what are your thoughts..
Recover My Flash Drive
 Post subject: Re: [SSD] M.2 LITEON CV3-8D512-11 - DEAD BEEF
PostPosted: October 20th, 2019, 16:49
ISTM that all the voltages are present (1.0 core, 1.8V and 1.5V). I would check the 4-pin ICs. I suspect that they are load switches, in which case you should measure the same voltages at their Vin and Vout pins.
Users browsing this forum: No registered users and 128 guests
