[SSD] M.2 LITEON CV3-8D512-11 - DEAD BEEF
http://forum.hddguru.com/viewtopic.php?f=10&t=39047
Author:  jeremyb [ October 20th, 2019, 14:29 ]
Post subject:  [SSD] M.2 LITEON CV3-8D512-11 - DEAD BEEF
Drive is undetected, I tried shorting what I assume is the factory jumper.. same result..
I tried Freeze spray, nothing stands out as overheating..
I uploaded a high resolution photo below with a few measurements (click download on the top left to see the full image)... Not sure if its FTL corruption or physical damage.
https://recovermyflashdrivecom-my.share ... w?e=7f8H5l
@fzabkar what are your thoughts..
Author:  fzabkar [ October 20th, 2019, 16:49 ]
Post subject:  Re: [SSD] M.2 LITEON CV3-8D512-11 - DEAD BEEF
ISTM that all the voltages are present (1.0 core, 1.8V and 1.5V). I would check the 4-pin ICs. I suspect that they are load switches, in which case you should measure the same voltages at their Vin and Vout pins.
