SSD Drevo with SM2258XT stuck at BSY in PC3000 not deteced i
http://forum.hddguru.com/viewtopic.php?f=10&t=39157
Author:  nicoalbrecht [ November 19th, 2019, 6:42 ]
Post subject:  SSD Drevo with SM2258XT stuck at BSY in PC3000 not deteced i
SSD Drevo with SM2258XT stuck at BSY in PC3000 not detected in DDI4
Controller is getting warm operational temperatures.
Any idea what to do?
Author:  HaspHL [ November 19th, 2019, 7:04 ]
Post subject:  Re: SSD Drevo with SM2258XT stuck at BSY in PC3000 not detec
https://blog.acelaboratory.com/pc-3000- ... ility.html
Author:  northwind [ November 19th, 2019, 8:19 ]
2258XT is not supported by PC3000.
Author:  fzabkar [ November 19th, 2019, 15:27 ]
You might like to try this.
In-circuit recovery of SSDs with "weak" NAND:
http://www.hddoracle.com/viewtopic.php?f=106&t=2740
Author:  csava [ November 28th, 2019, 11:24 ]
I can solve the sm2258xt busy state with a success rate of 80% - 90%. Please remove the fault on the circuit first. If it is still busy state, you can transfer it to me for solution
Author:  csava [ November 28th, 2019, 11:34 ]
I recently started running my YouTube channel, which doesn't have many videos.https://www.youtube.com/channel/UCTFwIP ... subscriber
More videos on bilibilibili.com https://space.bilibili.com/30865505
Recently, sm3281 and cbm2199 controllers are under development, which can solve about 30%
Author:  csava [ December 1st, 2019, 8:17 ]
Thousands of dollars of recovery tools for free
2258XT.rar [1.01 MiB]
Downloaded 1111 times
Author:  Arch Stanton [ September 12th, 2020, 17:09 ]
Your YouTube is dead, shame. Now I have to go through the Chinese site for which English translation sucks.
https://www.bilibili.com/video/BV1ni4y1u7vf skip to 2:28.
Looks like your using my software, cool.
Author:  csava [ September 12th, 2020, 23:50 ]
Hello, Joep. I didn't expect to meet you here. Thank you for your very useful tool. In fact, it's one of the best photo restoration tools I've ever used. Here are some suggestions for you: 1. Add the shortcut key of direction key to make the virtual key bigger (too small often leads to wrong operation) 2. Add the function of overall zooming in picture, which is more intuitive than local zooming.
The video of our domestic website was robbed before, and there was a video on YouTube without my permission. I fed back this incident to youtube, but my channel account was blocked (I was helpless, but YouTube didn't act, and email didn't reply. You know, when the language is different, simple things get complicated) it's very painful for you to see my video without translation, and it's the same with my English video without translation or using machine translation. I tried to find time to learn English, but I didn't have time
(this reply uses machine translation)
Author:  Arch Stanton [ September 13th, 2020, 9:04 ]
"1. Add the shortcut key of direction key to make the virtual key bigger (too small often leads to wrong operation) "
I'm not sure what you mean by that ..
"2. Add the function of overall zooming in picture, which is more intuitive than local zooming."
Yes, I know. And you're right. Problem kinda is I am not that much of a programmer and this kind of organically grew to what it now is .. Probably a lot of stuff what I will need to rewrite so this is why I'm kind of ignoring this .. But it's something I'll address. 9 out of 10 times if you actually start working on something like this, it's all a lot easier than you imagined beforehand.
Thanks for you feedback though!
"I was helpless, but YouTube didn't act, and email didn't reply"
Yes, it appears as if Youtube has become a beast that largely runs "on it's own". If you run into some kind of issue it's hard to get a human to actually help you. And if you finally get a human to help and correct things, 'algorithms' undo his work one hour later. Far less serious than your case, one of the thumbnails of my videos, according to some algo violates YT policies or whatever. But it's just a screen capture from the video itself. I now have had a human correct it 5 times. Each time after the video thumbnail then re-appears, the algo takes it down again. Such bullshit.
Author:  csava [ September 13th, 2020, 9:14 ]
Yes, it appears as if Youtube has become a beast that largely runs "on it's own". If you run into some kind of issue it's hard to get a human to actually help you. And if you finally get a human to help and correct things, 'algorithms' undo his work one hour later. Far less serious than your case, one of the thumbnails of my videos, according to some algo violates YT policies or whatever. But it's just a screen capture from the video itself. I now have had a human correct it 5 times. Each time after the video thumbnail re-appears, the algo takes it down again. Such bullshit.
Make the virtual buttons bigger, which will improve the convenience of my operation (especially when working out without a mouse, I can only use the touch pad that comes with my laptop)
Or let the commonly used function keys have shortcut key function, which can be operated by keyboard
Author:  Arch Stanton [ September 13th, 2020, 9:16 ]
Ah! Thanks, understood!
Author:  csava [ September 13th, 2020, 9:24 ]
Thank you for taking my advice. I hope the software will be better and better. Maybe in the future, there will be opportunities to cooperate in the extraction of original NAND data, and I can solve many thorny problems that cannot be solved by laboratories. Sometimes you lose confidence in finding a lab that can solve the problem (because it can't be solved, it can only be returned by the original route)
I work at home, and I don't directly face the guests. Most of my work is to solve problems that other city data recovery labs can't solve
Author:  Arch Stanton [ September 13th, 2020, 19:11 ]
FWIW I made a similar time lapse video of patching a JPEG https://youtu.be/Cci2H4EXvGk
