 Post subject: No access data!
PostPosted: June 25th, 2018, 9:37
Hi to all!
Please help!
Look print screen.
Attached.
Нет ничего невозможного
 Post subject: Re: No access data!
PostPosted: June 26th, 2018, 8:04
Hello!
Nohelp!
Is help is PV in solution! Buy! $$
Thanks!
PostPosted: June 27th, 2018, 12:53
which model is this?
PostPosted: June 29th, 2018, 8:45
KINGSTON 120 GB
SA400S37/120G
Please look is print screen.
Thanks!
I have two equal cases here for data recovery.
the other ssd and kingston 480gb
PostPosted: June 29th, 2018, 19:57
"SATAFIRM S11" --> Phison S11 Controller (PS3111-S11)
PS3111-S11 specification:
http://tophitech.com.cn/uploads/2016/12/252048579143.pdf
PostPosted: June 30th, 2018, 5:04
sempre wrote:
KINGSTON 120 GB
SA400S37/120G
Thanks!
i mean something similar to those images more clear
https://ru.gecid.com/data/storag/201706 ... 7_240g.jpg
about the other Kingston 480gb i think its SF
PostPosted: June 30th, 2018, 8:53
I think it will be Phison PS3111-S11. Sandforce controller is bigger ;)
PostPosted: July 2nd, 2018, 8:16
einstein9 wrote:
sempre wrote:
KINGSTON 120 GB
SA400S37/120G
Thanks!
is photos ssd 120 gb
PostPosted: July 2nd, 2018, 8:23
is ssd 480 gb
PostPosted: July 2nd, 2018, 17:15
ISTM that the "480GB" SSD might actually be a 360GB model (120/240/360/480) :?
2 x NW840 + 2 x NW838 = 2 x 1Tbit + 2 x 768Gbit = 442GB
3 x NW837 = 3 x 384Gbit = 144GB
Micron FBGA & Component Marking Decoder (replace %s with FBGA code):
[url]https://www.micron.com/support/tools-and-utilities/fbga?fbga=%s[/url]
MT29F384G08EBCBBJ4-37:B, Micron, NAND flash, FBGA Code = NW837, 384Gbit, 48GB x 8, 267MHZ, TLC, VBGA-132:
MT29F768G08EECBBJ4-37:B, Micron, NAND flash, FBGA Code = NW838, 768Gbit, 96GB x 8, 3.3V, TLC, x8, 533 MT/s, VBGA-132:
[url]https://www.micron.com/parts/nand-flash/3d-nand/mt29f768g08eecbbj4-37?pc={9A0C5709-8ECA-4DE8-B2AD-12CE9FC958E3}[/url]
MT29F1HT08EMCBBJ4-37, Micron, NAND flash, FBGA Code = NW840, 1Tbit, 128GB x 8, 3.3V, 3D NAND, x8, VBGA-132:
[url]https://www.micron.com/parts/nand-flash/3d-nand/mt29f1ht08emcbbj4-37?pc={9E356F28-3F5E-4FF7-A8D5-657A26EC58BE}[/url]
PostPosted: July 4th, 2018, 15:27
Yes correct!
currently pc3k does not support this model!
No solution??
PostPosted: July 5th, 2018, 2:32
Yes correct!
No solution??
Hi to all!!
No solution??
PostPosted: July 5th, 2018, 3:32
sempre wrote:
Yes correct!
No solution??
Hi to all!!
No solution??
sorry for the late reply.. was busy with some cases here,,,
can you post the terminal output of it?
PostPosted: July 5th, 2018, 5:20
You are right Michal, its not supported in 3k yet
sempre wrote:
Yes correct!
No solution??
Hi to all!!
No solution??
I think the only solution is by removing those chips (cannot repair)
(sorry you may ignore my prev. terminal Question..)
I knew that i had this SSD in hand (working in my lab) just found it
here is the HQ image of it...
https://drive.google.com/drive/folders/ ... sp=sharing
i tried to attach here many times but seems something is wrong preventing the upload to the post :roll:
PostPosted: July 31st, 2018, 10:39
Hi!!
4 cases waiting solution!
PostPosted: August 1st, 2018, 7:59
Solution!
PostPosted: August 1st, 2018, 14:52
What was your solution?
PostPosted: November 23rd, 2018, 14:30
sempre wrote:
Solution!
How did you fix it?
PostPosted: November 23rd, 2018, 16:51
PC-3000 SSD. Phison Utility (08/08/2018):
https://blog.acelaboratory.com/pc-3000-ssd-phison-utility.html
Right now the list of supported models includes the following cpu modifications:
    Phison PS3105 (all modifications and all models);
    Phison PS3108-S8 (all modifications and all models);
    Phison PS3109-S9 (all modifications and all models);
    Phison PS3110-S10 (all modifications and all models);
    Toshiba TC58NC1000 (all modifications and all models);
    Phison PS3111-S11 (all modifications and all models);
    Kingston CP33238B (all modifications and all models)
PostPosted: June 15th, 2019, 22:18
If anyone landing on this thread wants to recover their drive (but not their data), then here is a solution:
https://forums.tomshardware.com/threads/kingston-satafirm-s11-fix.3489081/
https://drive.google.com/file/d/1irsjAzhxf9VTr24MkPfqvz7b1dhmQ98O/view
WARNING: This procedure is data destructive!
repairs11.rar [17.49 KiB]
Downloaded 1289 times
