HDD GURU FORUMS
http://forum.hddguru.com/
MZ-jpv128r/0a2 freezing - adapter needed
http://forum.hddguru.com/viewtopic.php?f=10&t=39302
Page 1 of 1
Author:  boerge [ December 30th, 2019, 19:16 ]
Post subject:  MZ-jpv128r/0a2 freezing - adapter needed
Dear friends,
best job between christmas and new year ... i'm working on an apple "Samsung MZ-jpv128r/0a2" from macbook air early 2014. The guys in the apple-store couldnt recover any data, so customer needs "fast" help.
Long story, big (or not?) problem.
When customer came in, i tried the SSD with PCIe-Adapter under linux-environment and it was recognized - after he was gone i tried this again to copy the data and the drive was gone also.
After about 1 hour i tried again and could copy 2% with dd_rescue - then the drive freezes. On next restart it wasn't recognized. One hour later i could initialize the drive again and read 3% backward - then still freezing.
So i decided to work with pc3k and installed the adapter in our DR-machine. But System doesn't start until Windows-Logo. After 4 attemps Windows starts and i could copy 1% of data with data-extractor - then still freeze.
With PC3K-DE and this pcie-adapter i cannot handle any reading-errors (soft/hard-reset or power on/off...) or play with timings. And if the drive freezes i have to restart/power off the machine until the drive comes ready again.
So i'm searching for a solution to "hotplug" the PCIe-drive every time it is freezing without restarting the whole machine. I found this https://www.amazon.de/QNINE-Adapterkart ... s=1&sr=8-3 and this https://www.ebay.de/itm/M-2-NVME-SSD-zu ... Sw1pddS6KA . With this adapters it should be possible to restart the drive every time it freezes, or not?
Can anybody help?
Thanks and happy new year to all of you!
Author:  LarrySabo [ December 30th, 2019, 20:29 ]
Post subject:  Re: MZ-jpv128r/0a2 freezing - adapter needed
This sounds like a good case for DeepSpar's USB Stabilizer+USB adapter.
Author:  pcimage [ December 31st, 2019, 5:37 ]
Exactly what I was thinking! A perfect candidate :-)
Author:  digisupport [ December 31st, 2019, 6:58 ]
ACELab“s PC-USB PWR adapter + USB adapter will also do the job :)
Author:  boerge [ January 2nd, 2020, 15:57 ]
@larrysabo and pcimage: Thanks - i'll try with my cheap solution. DeepSpar-Tool sounds good but isn't an option at this time.
If this doesn't work i'll come back.
@digisupport - drive is PCIe - ACE-adapters only work with SATA-based drives
Author:  digisupport [ January 3rd, 2020, 5:07 ]
Not sure about your actual model, have non of them registered. Imaging a MZ-JPU512T/0A6 right now.
ACE PC-USB PWR adapter + PCIe2USB adapter like this one works fine https://eshop.macsales.com/item/OWC/MAU3ENPRPCI/
Will also let you control power directly from DE.
http://www.phpbb.com/
