 Post subject: Samsung mobile phone - DR after reset
PostPosted: January 4th, 2020, 16:13
I have a Samsung phone which get resetted to factory defaults.
I was using KingRoot + BusyBox to be able to image the whole internal memory with dd. Then I tryed to recover lost files from the image but there where no files. When I inspect that image with an hexeditor i see that over 85% are filled with 0x00 or 0xFF.
I had in the past luck with that method on an Android 2.x phone....
Does phones whipe the internal memory newadays when they get resetted? Or do the controller only deliver 0x00 / 0xFF because that space is not in use?
Would a Chip-Off make sence in that case? It's a eMMC Memory in that phone and I would have an eMMC to SD Adapter here but I am not sure if that make any sence...
 Post subject: Re: Samsung mobile phone - DR after reset
PostPosted: January 5th, 2020, 2:42
new phones are By Default Encrypted, Factory Reset means Generating new Encryption key which means again Data Gone
I got to know from some people that chip-off & trying to restore the "Old Key" (in some cases) >> Did work..... Maybe but not as a rule for the rest
to cut it short : When you hear Factory Reset (IOS/Android) then just don`t bother
PostPosted: January 5th, 2020, 6:26
... Sorry forget to tell the model - it's an older S3 but i don't know when Samsung started with encryption.
And if the encyption-key got changed i would get at least some garbage-data in the dump or not?
PostPosted: January 5th, 2020, 13:21
Only chip-off method will give you chance to recover something, when mobile phone do not encrypt the data. Of course need read directly from nand memory, not by SD/eMMC interface. What is the model of eMMC?
PostPosted: January 5th, 2020, 16:27
It should be a BGA 153 or BGA 169 - don't have the phone with me or opend yet...
The only adapter I have right not is one of them:
https://www.amazon.de/ALLSOCKET-eMMC153 ... 2C170&th=1
On some other phone with a broken display it did the trick a while ago but I am not sure if the i9300 encrypts the memory or whipe the data while resetting. I where thinking a technique to gather a forensic image would also get deleted files. By the way i was using that method: https://dfir.science/2017/04/Imaging-An ... nd-dd.html
PS.: I know installing Software on the Chip is not a good idea but the owner ask me to try a non destructive technique first.
PostPosted: January 5th, 2020, 19:59
On this mobo could be this chip: http://odzyskiwanie-danych.com.pl/image ... arvika.jpg
Because it was released on Android 4, data should be not crypted.
We have pinout for nand.
Do not instal any software on phone, it is usless, and dangerous for data (overwritten). Adapter you linked does not help for this case.
PostPosted: January 6th, 2020, 4:48
... and which adapter would help?
PostPosted: January 6th, 2020, 5:02
This adapter is using memory's controller. You need to connect directly via NAND protocol. So you need to find a pinout or check Rusolut eMMC-NAND Reconstructor.
odzyskiwanie danych
PostPosted: January 6th, 2020, 5:28
Ok thanks - that helped. I found a PDF from Rusolut. So after deleting or a factory reset the Controller inside the eMMC delivers a 0x00 for not allocated memory. But with bypassing the eMMC-controller with VNR you are able to get the data directly via NAND-protocol. Now I get what you mean!
PostPosted: January 6th, 2020, 5:47
Yes, exactly. Controller "cheats" the user. But this method works only for old mobile phones. All new one is crypted so this method will not work.
PostPosted: January 7th, 2020, 5:51
This phone with a chance of 95% is not encrypted.
We did bunch of tests of eMMC-NAND Reconstructor on the chips from S3 and got loads of data after factory reset (usually it's either Samsung or Toshiba chips both very likely supported).
In my experience S3 is among the phones that leaves a richest amount of data after reset :)
Of course you won't be able to get videos, but plenty of text data and some JPEGs too.
VISUAL NAND RECONSTRUCTOR. Since 2014.
PostPosted: January 8th, 2020, 2:23
@ Sasha Sheremetov
I think the time/work for this case vs output results later will not be much btw, sometimes end up with dead phone.
@ maddin
You can try it and post here the results later (just to know how good/bad it was)
good luck
Users browsing this forum: No registered users and 24 guests
