| Intel 160GB SSD Model: SSDSA2BW160G3H 8MB FAIL http://forum.hddguru.com/viewtopic.php?f=10&t=39350 |
Page 1 of 1 |
| Author: | linusmay [ January 13th, 2020, 4:36 ] |
| Post subject: | Intel 160GB SSD Model: SSDSA2BW160G3H 8MB FAIL |
Hello, this is my first post to the group. I am a RAID config repair engineer. ....But i am stuck with an SSD disk with a problem not related to RAID... Its an Intel 160GB SSD Model: SSDSA2BW160G3H It has a 160GB capacity, but now shows only 8mb. This is apparently a known failure of the firmware, that apparently is NOT recoverable. Here is a link to a technical advisory notice sent to all Intel SSD owners, (FROM THE MANUFACTURER), explaining the problem and confirming there is no known solution. https://www.techspot.com/news/44694-int ... lable.html https://www.tested.com/forums/pc-and-ma ... tion-here/ …….Intel released a fix for drives that have not yet failed, but the fix does NOT work on drives that already have failed. The fix will only ‘factory reset’ the disk to an empty fully working 160GB disk, but the data will be erased. Can anyone find out if a solution is still not possible, or if a new fix is available for this disk model? Kind regards Linus May |
| Author: | samstown [ January 13th, 2020, 7:45 ] |
| Post subject: | Re: Intel 160GB SSD Model: SSDSA2BW160G3H 8MB FAIL |
Hello, i had a similar case two years ago and I was able to retreive the data. I'll check Model and let you know. |
| Author: | pcimage [ January 13th, 2020, 16:45 ] |
You have PM |
