 Post subject: Outsourcing flash task
PostPosted: March 12th, 2020, 7:37
Hello guys,,
Am looking for someone expert in flashes MPtools... etc.
I have in stock Qty. of flashes (Identical) which i want to create a customized VCD partition, i really don`t have time to go through the task but willing to outsource it.
I just need the proper working tool from your side for my flash..
here is the details for the flash (chip-genius):
___________________________________________________
Description: [G:]USB Mass Storage Device(USB DISK 2.0)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 13FE PID = 4300
Serial Number: 90009A565366D471
Device Name: USB DISK 2.0
Device Revision: 0100
Product Model: USB DISK 2.0
Product Revision: PMAP
Controller Vendor: Phison
Controller Part-Number: PS2251-70(PS2270) - F/W 07.06.10 [2019-09-02]
Flash ID code: 983C98B3 - Toshiba [TLC]
Tools on web: http://dl.mydigit.net/special/up/phison.html
Will provide you with TV to test it and verify it with sample flash if needed
PM for Quote. & details...
Thank you
 Post subject: Re: Outsourcing flash task
PostPosted: March 12th, 2020, 18:05
What are you trying to do..
At one point I tried using the low level SCSI commands implemented by the MPTools to try and recover monolithics using a custom rom I wrote in assembly (the controller has its own CPU) but it was a headache because I could only get specific modes / commands to work (ie: ID, STD Read/Write, etc) then again I didn't fully understand it..
Is that your goal?
Recover My Flash Drive
PostPosted: March 12th, 2020, 20:08
I believe the goal is to create some kind of USB containing marketing material that cant be just deleted and then the USB used for storage.
Think InfoSec Conference swag.
Nothing like BadUSB though...
PostPosted: March 13th, 2020, 1:12
I "think" MPTools let you create an ISO which mounts as a virtual cdrom
PostPosted: March 14th, 2020, 2:03
exactly...
