burnt out crucial MX 100 help
http://forum.hddguru.com/viewtopic.php?f=10&t=39614
Author:  Josipe [ March 18th, 2020, 14:13 ]
Post subject:  burnt out crucial MX 100 help
my psu seems to have burnt out my mobo, 3 harddrives, and my cpu. luckily my main drive seems to have survived. the mx 100 however did not and i seem to have identified the point of failure and just need some assistance in identifying the chip as well as how i might be able to repair it. im a newb when it comes to this stuff so please explain things to me in detail when ti comes to testing and repair. i saw the post of the person whos mx100 failed however he seemed to have a less obvious problem than i do. any help is greatly appreciated. thank you. pictures below
Author:  data-medics [ March 18th, 2020, 17:23 ]
Post subject:  Re: burnt out crucial MX 100 help
I believe it's a power IC. Probably this one: https://www.aliexpress.com/item/32532393392.html
But, don't be surprised if there are other burned out components.
Author:  fzabkar [ March 18th, 2020, 17:41 ]
See https://forum.hddguru.com/viewtopic.php?f=10&t=33908
There are some errors in that thread, so make sure you read it all.
The visibly damaged chip is a TLV62080. Note that these PCBs are poorly protected (or not protected at all), so an overvoltage tends to do a lot of damage, most of which isn't visible.
BTW, judging by the damage in your other threads, you appear to have done this:
Warning: do not interchange modular PSU cables:
http://www.hddoracle.com/viewtopic.php?f=56&t=2545
Author:  fzabkar [ March 18th, 2020, 18:46 ]
That doesn't look right.
"JAGR" is a TI "5-V, 1:1 (SPST), 2-channel general-purpose analog switch", p/n TS5A2066DCUR.
Author:  Josipe [ March 18th, 2020, 18:53 ]
i believe the unit that is visibly burnt is an rau unit. not totally sure on that though. was hoping for some confirmation. thank u guys for responding i appreciate it
Author:  data-medics [ March 19th, 2020, 11:40 ]
I was looking at the item listing title which said it was RAU marked (which is what I searched for). I see that the picture is different, I never actually looked at the photo on the aliexpress listing. Looks like the component can be obtained directly from Texas Instruments here: http://www.ti.com/product/TLV62080/samp ... #samplebuy
Author:  Josipe [ March 19th, 2020, 20:37 ]
i would be lucky if that is the only thing fried. do u think this can be done with a soldering iron and solder paste? or do i have to use a hot air gun?
Author:  Josipe [ March 19th, 2020, 20:49 ]
data-medics wrote:
data-medics wrote:
I believe it's a power IC. Probably this one: <!-- m --><a class="postlink" href="https://www.aliexpress.com/item/32532393392.html">https://www.aliexpress.com/item/32532393392.html</a><!-- m -->
I was looking at the item listing title which said it was RAU marked (which is what I searched for). I see that the picture is different, I never actually looked at the photo on the aliexpress listing. Looks like the component can be obtained directly from Texas Instruments here: <!-- m --><a class="postlink" href="http://www.ti.com/product/TLV62080/samplebuy?CMP=conv-poasamples#samplebuy">http://www.ti.com/product/TLV62080/samp ... #samplebuy</a><!-- m -->
which one of those should i buy? im a little confused because they have different model numbers
Author:  Josipe [ March 22nd, 2020, 23:28 ]
what is the difference between the TLV62080DSGR and the TLV62080DSGT?
