Flashpen - Bended on PC tower
http://forum.hddguru.com/viewtopic.php?f=10&t=39713
Author:  samstown [ April 14th, 2020, 11:48 ]
Post subject:  Flashpen - Bended on PC tower
Hi guys,
I got this USB 128GB flash drive, was working until customer bended it while moving PC tower. I've tried to check connection and solder a cable on PCB but no result. USB is not detected at all, nothing, I wonder if it could be a fuse but I don't see anything reference to fuse on PCB. Any Idea ?
Sam
Author:  ddrecovery [ April 14th, 2020, 12:02 ]
Post subject:  Re: Flashpen - Bended on PC tower
Is the bend in the logic board real?
Or is it the way the picture is taken?
If the board is that bent in real life, you will need to do a chip off.
Author:  samstown [ April 14th, 2020, 12:49 ]
sorry, there's now visible bend on PCB, it's the magnifying glass effect.
Author:  ddrecovery [ April 14th, 2020, 13:03 ]
If its been bent, it is unlikely to be just a fuse which has blown. I would suggest checking each of the legs on the controller and NAND chips for a bad connection. Test components such as caps for shorts. Many times when the board has been bent the short can be within the lamination layers of the board so its impossible to trace. A chip-off may be your only option if you cant trace the issue.
Author:  arvika [ April 14th, 2020, 15:08 ]
Check oscillator.
Author:  HaQue [ April 15th, 2020, 11:39 ]
Also, check under a 10x microscope. easy to miss breaks with just magnifying glass.
Author:  fzabkar [ April 15th, 2020, 18:11 ]
https://opendevices.ru/wp-content/uploads/2011/11/USBest_UT165.pdf
R12 appears to be the "fuse".
Author:  samstown [ April 16th, 2020, 14:46 ]
This is awesome, thank you. I'll give it a try.
Author:  samstown [ April 18th, 2020, 2:39 ]
R12 didn't help. I'll go for chips off.Thank you all for your help.
Author:  arvika [ April 18th, 2020, 3:21 ]
Did you check oscillator?
Author:  Amarbir[CDR-Labs] [ April 18th, 2020, 6:40 ]
Hello Frank ,
Do You Have Other Controllers Datasheets Also ,Any Websites You Can Share For Such Content
