USB Key 32GB - Drive not detected at all, little LED is on
http://forum.hddguru.com/viewtopic.php?f=10&t=39727
Author:  samstown [ April 16th, 2020, 14:54 ]
Post subject:  USB Key 32GB - Drive not detected at all, little LED is on
Hi guys,
I got that USB Key 32 GB. The drive is not detected at all however the little led does turn on red, steady, not flashing. I am looking for the oscillator but it must be SMD and I am not sure which one. I tried searching using the info on PCB but can't find anything relevant.
Sam
Author:  pepe [ April 16th, 2020, 17:06 ]
Post subject:  Re: USB Key 32GB - Drive not detected at all, little LED is
That controller is probably using an internal oscillator.
I would check in the device manager, if it comes up in the disk drives section as the controller name with 0 capacity.
If it does, the problem is probably in the NAND.
Author:  samstown [ April 17th, 2020, 2:49 ]
It's odd as there's nothing on W10 Disk Management or MacOS disk Utility however the light is on. It looks like controller doesn't talk to PC ?
Author:  pepe [ April 17th, 2020, 5:17 ]
It would take at least an oscilloscope to check if it really talks over the usb (or a proto analyzer) and the NAND.
There's not much you can do without tools, apart from checking broken soldering...
Author:  samstown [ April 17th, 2020, 6:06 ]
Yeah, I'll get an oscilloscope today.
Author:  samstown [ April 18th, 2020, 8:09 ]
I've made some progress. I've connected 5V to controller U1, now USBkey is recognized by PC. I can't yet access data, USB is listed but not can't initialize it, doesn't report capacity. I am sharing if that can help someone.
Author:  samstown [ April 18th, 2020, 8:27 ]
Looks like the problem is the "write-protect" now.
Author:  pepe [ April 18th, 2020, 8:29 ]
i guess it is time for a chip-off. Can you handle it?
