Macbook Pro Retina SanDisk SSD
http://forum.hddguru.com/viewtopic.php?f=10&t=39729
Author:  dvs12c [ April 17th, 2020, 7:09 ]
Post subject:  Macbook Pro Retina SanDisk SSD
Chasing some component details for a Sandisk SSD
This is a 512GB from a MacBook Pro 15" Retina A1398 Early 2013
Author:  fzabkar [ April 17th, 2020, 18:01 ]
Post subject:  Re: Macbook Pro Retina SanDisk SSD
I suspect that it is a dual MOSFET switch. If so, then you can remove it and bypass it with a jumper wire.
I would test for shorts to ground at each of the inductors, and at the damaged IC, after removing it.
If you need more help, upload detailed photos of both sides, after removing the damaged IC.
See https://forum.hddguru.com/viewtopic.php?f=10&t=36450
