 Post subject: Samsung NVMe PM591 (MZ-VLW5120)
PostPosted: March 26th, 2020, 10:51
Hello.
I've Samsung NVMe drive PM591 (MZ-VLW5120 ) . It comes from Lenovo X1 Carbon (5th gen). Last time my notebook gets down to floor. After that it stop working (I suppose it's mainboard issue). However, I remove NVMe disk from it and try to use in new Lenovo Carbon. Once I power up I got error 2100: Detection error on Storage Device (M.2 ) . So it looks like NVMe gets faulty or something.
I try to read NVMe in external M.2 -> USB adaptor but it is not recognized.
Is there anything else that I can do (such safe mode things etc) to try to get it works?
Please for help.
Thanks,
Greg
 Post subject: Re: Samsung NVMe PM591 (MZ-VLW5120)
PostPosted: March 26th, 2020, 16:12
You need an adapter/enclosure that has a USB-NVMe bridge, not USB-SATA.
http://www.hddoracle.com/viewtopic.php?f=106&t=2853
PostPosted: March 27th, 2020, 3:49
Hi. Thank you for your reply. I have Tracer NVME 702 AL adapter. Manufacrurer says it is for m.2 NVMe. How can i check compatibility?
PostPosted: March 27th, 2020, 18:01
Can you upload detailed photos of each side of the Tracer PCB and Samsung PCB?
PostPosted: March 28th, 2020, 3:39
Here are pictures of NVMe -> USB :
https://imgur.com/IxXHzDi
https://imgur.com/uUgI2Yi
https://imgur.com/U1F4rrE
Here NVMe drive:
https://imgur.com/1BRhRT7
https://imgur.com/5KpjwjY
PostPosted: March 28th, 2020, 20:56
The adapter does have an NVMe bridge (JMS583).
I would measure the following voltages on the SSD:
PostPosted: March 29th, 2020, 6:46
Test are made on NVMe -> USB adapter
v1 (inductor) - 1.835 V
V2 - 1.084V
V3 - 1.79V
v4 (inductor) - 1.084 V
V5 - 1.249 V
vboost - 12.02V, after some seconds it start going down to 0.3 v and then gets down to 0.20v
PostPosted: April 23rd, 2020, 2:35
Hi.
Is there anything more I can do ? and possibility to repair drive?
PostPosted: April 23rd, 2020, 3:18
ISTM that the supply voltages are probably OK. It may be that the SSD has a "firmware fault".
Otherwise, I would check the crystal, just in case it was shattered by the fall.
PostPosted: May 9th, 2020, 5:38
Hi. Thanks for answer. Is there any possibility to repair firmware on that NVMe? What you mean by "crystal" ?
PostPosted: May 9th, 2020, 17:18
This looks like the crystal:
The crystal is cut from quartz which can be shattered by a sharp impact. Often you can hear the shards rattling inside the metal case.
AFAIK, there is currently only one [very expensive] professional tool that can deal with NVMe SSDs at the firmware level. In any case I believe recent Samsung SSDs have not yet been reverse engineered (due to encryption).
