 Post subject: SanDisk Milpitas 16KB
PostPosted: January 5th, 2022, 20:33
so , i have a sandisk ssd plus "SDSSDA-240G" that apear on the bios as SanDisk Milpitas (all of the sudden), it shows on recovery software a 16KB when its a 240GB ssd .
what i suspect the 16kb is , is just the controller on the SSD .
from reading abit online is a common thing on sandisk ssd ,
"SSD is stuck in a panic state where it is unable to fully load the firmware from the service areas on the NAND chips"
https://www.recoveryforce.com/sandisk-s ... -recovery/
or pc3000 https://www.youtube.com/watch?v=-BlAaDd9KYk
the blog post does not describe how he got that to work, and i dont have a pc3000 device .
help would be great ;)
thanks !
 Post subject: Re: SanDisk Milpitas 16KB
PostPosted: January 6th, 2022, 2:09
You wil not get it to work. Milpitas is a real pita. Haven't seen anyone recovering that. It's not supported by PC3000 yet.
odzyskiwanie danych
PostPosted: January 6th, 2022, 3:50
We recover many of this. But success rate depends on condition of memory modules. Usually is big or very big.
PostPosted: January 6th, 2022, 10:52
condition are pretty good tbh , not alot of read/write on the memory module , and its kinda new like exactly 3.2 years on the ssd i was in shock
PostPosted: January 6th, 2022, 10:55
btw , if you look into the youtube link i sent , they did recover it .
from my understanding this type of ssd drivers are the same , wd-green and sandisk if you look online WD ssd urned into milpitas sandisk :)
PostPosted: January 6th, 2022, 12:41
WD green is based on Sandisk controller and they are shown as milpitas when they fail. Those based on Marvell are doable in some cases. Most of Sandisk work till they die totally so theres not much to recover. Not like PS3111 based ones.
odzyskiwanie danych
PostPosted: January 6th, 2022, 13:46
I do not agree. So far all my WD cases based on Sandisk controller 20-82-00469-2 was recoverable by chip-off method.
PostPosted: January 7th, 2022, 2:00
My bad. I should have written that they cannot be done via SATA. As OP wrote "the blog post does not describe how he got that to work, and i dont have a pc3000 device ."
So there's no way for him to do it at home.
odzyskiwanie danych
PostPosted: January 7th, 2022, 6:13
the blog post doesn't show or explain how they done that , and yes i dont have a pc3000
back to my original post .
how is it possible to recover the drive (lets say i did not care about the data inside .)
is that possible for example to replace the controller ?
i'd bet the memory modules (memory nand chips) are fine
PostPosted: January 7th, 2022, 9:11
I bet the opposite. That the controller is good, and memories are damaged/ problematic.
It's not worth the effort to repair it but you can try to force FW upgrade or flash.
odzyskiwanie danych
PostPosted: January 8th, 2022, 16:22
right , because the 16KB is basically the controller ..
although the controller holds the FW no ?
how can i force a fw upgrade/flash ?
i am looking for some guides or videos that can help me out .
note that this is for education purposes and not necessarily receover the data inside
PostPosted: January 9th, 2022, 1:02
FW is on NAND.
If you try to fix the drive, upgrade or flash it, you'll loose the data most probably.
odzyskiwanie danych
PostPosted: April 21st, 2022, 5:44
Hello everyone.
also i have a sandisk sdd sdssda-480g with the same problem 16 kb on 480g, SanDisk Milpitas.
I was wondering if the 16kb are the firmware maybe it is this part that is corrupt and does not continue to read the data, I tried to look for the frimware to try to rewrite it but it is not found, the chip on board is a sandisk so it is not recoverable with pc3000, i am not interested in recovering the data but i would like to recover ssd somehow.
PostPosted: June 14th, 2022, 4:48
This is about sm2246 controller
Not sandisk controller
PostPosted: June 14th, 2022, 4:52
This link is about the Sm2246 controller, not the SanDisk controller
PostPosted: June 27th, 2022, 7:51
same problem with wd green 480gb bricked with 16k. any solution yet ? please help !!!
PostPosted: January 12th, 2023, 6:55
the discussion was very interested, why not revive it again ? was there any update then by the time?
PostPosted: January 12th, 2023, 7:29
Those based on Sandisk controller can be recovered via chip-off.
odzyskiwanie danych
PostPosted: April 1st, 2023, 10:56
A New Update - > https://rusolut.com/visual-nand-reconstructor-7-2/
