| SanDisk SSD PLUS 240GB http://forum.hddguru.com/viewtopic.php?f=10&t=40191 |
Page 1 of 1 |
| Author: | sempre [ July 23rd, 2020, 7:44 ] |
| Post subject: | SanDisk SSD PLUS 240GB |
Model : SanDisk SSD PLUS 240GB Serial : Firmware : UF4500RL Capacity : 240 GB (468 877 312) proc sandisk 20-82-00469-2 SSD is not supported IS pc3000 ssd utilities. tool supported? Help me! |
| Author: | avajohonson2395 [ July 28th, 2020, 3:26 ] |
| Post subject: | Re: SanDisk SSD PLUS 240GB |
You got your solution or not? |
| Author: | sempre [ July 28th, 2020, 7:56 ] |
avajohonson2395 wrote: You got your solution or not? not solution! |
| Author: | yuanyasmine [ July 30th, 2020, 2:25 ] |
I have the same issue. Hope be supported in the next update.. |
| Author: | LostDataSa [ September 27th, 2022, 16:43 ] |
http://flash-extractor.com/library/SanD ... 98_b3__4x1 |
| Author: | Lardman [ September 28th, 2022, 4:23 ] |
LostDataSa wrote: http://flash-extractor.com/library/SanDisk/20-82-00469-2/20-82-00469-2__45_3c_98_b3__4x1 You're 2 years late and these drives are now supported under PC 3000 ssd.
| Author: | melvin [ September 28th, 2022, 4:27 ] |
Lardman wrote: LostDataSa wrote: http://flash-extractor.com/library/SanDisk/20-82-00469-2/20-82-00469-2__45_3c_98_b3__4x1 You're 2 years late and these drives are now supported under PC 3000 ssd.But reading them in PC3k is in 90% pointless. Sandisks work till they are in really bad condition. |
| Author: | Lardman [ September 28th, 2022, 4:45 ] |
melvin wrote: But reading them in PC3k is in 90% pointless. Sandisks work till they are in really bad condition. I know that the ssd plus with sandisk nand are like this having had one in recently, but I thought those drives with the mavel controller or other brand nand were fine?
| Author: | arvika [ September 28th, 2022, 14:31 ] |
Lardman wrote: You're 2 years late and these drives are now supported under PC 3000 ssd. As I know this controller is not supported by PC3K. |
| Author: | northwind [ October 5th, 2022, 3:34 ] |
Yeah, chip off is only option for those, no PC3K support. |
| Author: | lcoughey [ October 5th, 2022, 8:17 ] |
northwind wrote: Yeah, chip off is only option for those, no PC3K support. A very long and painful process, as I've recently discovered. |
| Author: | Amarbir[CDR-Labs] [ April 1st, 2023, 10:53 ] |
Lardman wrote: LostDataSa wrote: http://flash-extractor.com/library/SanDisk/20-82-00469-2/20-82-00469-2__45_3c_98_b3__4x1 You're 2 years late and these drives are now supported under PC 3000 ssd.Well, Were does it state its supported ? |
| Author: | Lardman [ April 1st, 2023, 15:39 ] |
Amarbir[CDR-Labs] wrote: Well, It isn't - I didn't see the OP had specified the sandisk controller rather than once of the many others found in the drives.
