Finding a suitable donor for NAND swap (USB stick)?
Posted: July 23rd, 2020, 8:35
Hi All,
I have a Kingston DataTraveler G4 8GB USB stick I need to recover files off. USB device is no longer detected on any hardware or OS, Windows doesnt even show it in disk management (but still makes the connection sound). No luck being detected in Linux either.
I have removed the NAND and read it through Rusolut, no issues with the data but without the controller and layout I can't make heads or tails of it (another problem though). The controller is an SSS6131 which doesnt seem common (all the other Kingston 8GB sticks I have checked have the Phison controller)
I was thinking since NAND is working, easiest solution would be to put the NAND on a suitable donor, but what do i need to look out for in finding a suitable match? Is it just the the model on the PCB needs to match along with the model on the controller (also does the FULL model written on controller need to match, for example if I have:
SSS6131
H2-E6C
NST507-100B
1552
Is it sufficient for just the SSS6131 to match or not?)
Also does the GB size of the donor need to match (i.e. if I have a "donor" 16GB with matching board/controller) can the NAND just be transplanted onto that or does it still need to be an 8GB?
Sorry if these all seem like really silly questions, but I have Googled a lot and not come across anything to definitively answer these, any help is much appreciated, thanks!
SSS6131
H2-E6C
NST507-100B
1552
