| SD Card data recovery http://forum.hddguru.com/viewtopic.php?f=10&t=40333 |
Page 1 of 1 |
| Author: | morekid [ August 26th, 2020, 7:14 ] |
| Post subject: | SD Card data recovery |
Hi there, I'm trying to recover data from an unreadable SD Card. When attempting repair I get the following: Code: sudo fsck_hfs -ryd /dev/rdisk3s1 Unable to open block device /dev/disk3s1: Permission deniedjournal_replay(/dev/disk3s1) returned 13 ** /dev/rdisk3s1 (NO WRITE) Using cacheBlockSize=32K cacheTotalBlock=32768 cacheSize=1048576K. Executing fsck_hfs (version hfs-407.50.6). Block 2 is not an MDB or Volume Header Block 15597566 is not an MDB or Volume Header volumeType is 0 0000: 5553 4243 50c3 f80b 0004 0000 0001 0a2a |USBCP...........| 0010: 0000 0020 0000 0002 0000 0000 0000 0040 |................| 0020: 6d9c 26e1 8c7a e3d7 a54c ab24 a253 e6c5 |m....z...L...S..| 0030: 0c8d 9f24 c8c3 8c77 c77a c8da 36b6 83e1 |.......w.z..6...| 0040: eb00 9053 4420 2020 2020 2000 0240 2011 |...SD...........| 0050: 0200 0000 00f8 0000 3f00 ff00 0020 0000 |................| 0060: 0000 ee00 7007 0000 0000 0000 0200 0000 |....p...........| 0070: 0100 0600 0000 0000 0000 0000 0000 0000 |................| 0080: 8000 2901 0203 0420 2020 2020 2020 2020 |................| 0090: 2020 4641 5433 3220 2020 0000 0000 0000 |..FAT32.........| 00a0: 0000 0000 0000 0000 0000 0000 0000 0000 |................| . . . 01f0: 0000 0000 0000 0000 0000 0000 0000 0000 |................| unknown volume type primary MDB is at block 0 0x00 alternate MDB is at block 0 0x00 primary VHB is at block 0 0x00 alternate VHB is at block 0 0x00 sector size = 512 0x200 VolumeObject flags = 0x01 total sectors for volume = 15597568 0xee0000 total sectors for embedded volume = 0 0x00 CheckHFS returned 6, fsmodified = 0 Any pointers are appreciated on what the next steps would be! Thanks |
| Author: | Arch Stanton [ August 26th, 2020, 11:32 ] |
| Post subject: | Re: SD Card data recovery |
Don't attempt repair, it may ruin your chances. Try imaging/cloning it first (ddrescue or similar), then use file recovery software to recover the data. What type of device was the card use in? What type of data do you expect to be on there? |
| Author: | morekid [ August 27th, 2020, 1:51 ] |
Arch Stanton wrote: Don't attempt repair, it may ruin your chances. Try imaging/cloning it first (ddrescue or similar), then use file recovery software to recover the data. What type of device was the card use in? What type of data do you expect to be on there? Hi Arch, thanks. It's a mini SD with photographic material from a camera, I'm accessing it through an SD adapter > macbook port controller. |
| Author: | Arch Stanton [ August 27th, 2020, 4:31 ] |
OK. Yes, advise still stands. Image card, then recover the data, using DMDE, R-Studio or UFS Explorer (assuming you're trapped in a Mac environment). If data is worth > say $250 - $300 ask a lab to do it for you, some may even charge less for logical recovery. |
| Author: | morekid [ December 18th, 2020, 5:42 ] |
Arch Stanton wrote: OK. Yes, advise still stands. Image card, then recover the data, using DMDE, R-Studio or UFS Explorer (assuming you're trapped in a Mac environment). If data is worth > say $250 - $300 ask a lab to do it for you, some may even charge less for logical recovery. Thanks, advice worked! ddrescue > DMDE. I was able to clone the SD card and work exclusively on the image, read and restore files through DMDE. |
| Author: | Arch Stanton [ December 18th, 2020, 19:35 ] |
Awesome, thanks for follow up! |
| Author: | fzabkar [ December 20th, 2020, 15:29 ] |
If we strip off the first 0x40 bytes from the OP's sector dump, we are left with a standard FAT32 boot sector. Code: OEM identifier "SD " Bytes per Sector 512 Sectors per Cluster 64 Reserved Sectors 4384 Number of FATs 2 Root Dir Entries 0 Total Sectors 0 Media Descriptor F8h Sectors per FAT 0 Sectors per Track 63 Number of Heads 255 Hidden Sectors 8192 Total Sectors 15597568 Big Sectors per FAT 1904 Extended Flags 0000h FS Version 0000h Root Start Cluster 2 FS Info Sector 1 Backup Boot Sector 6 Reserved 00000000h Reserved 00000000h Reserved 00000000h Drive Number 80h Reserved 00h Ext. Boot Sign. (0x29) 29h Serial Number 04030201h Volume Name " " File System Type "FAT32 " Boot Signature (0xAA55) 0000h Is this normal? |
| Author: | Arch Stanton [ December 20th, 2020, 16:10 ] |
Oh, good catch. TBH I skipped the output but now you mention it, it is so bloody obvious that I wonder how I missed that. AFAIK this isn't normal. |
| Author: | Spotmen [ December 21st, 2020, 3:33 ] |
Hello fzabkar, Can you explain how you do that from the output from customer ? (it's Christmas week and very quiet in the office, good time to learn something). Thanks in advance. |
| Author: | Arch Stanton [ December 21st, 2020, 10:17 ] |
I don't know how Frank did, but you can just grab this eb00 9053 4420 2020 2020 2000 0240 2011 0200 0000 00f8 0000 3f00 ff00 0020 0000 0000 ee00 7007 0000 0000 0000 0200 0000 0100 0600 0000 0000 0000 0000 0000 0000 8000 2901 0203 0420 2020 2020 2020 2020 2020 4641 5433 3220 2020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 Pad it with zeros until you have 512 bytes and paste into a hex editor with a FAT32 boot sector template. |
| Author: | fzabkar [ December 21st, 2020, 14:15 ] |
I picked an empty sector in DMDE, say LBA 3, and then pasted the hex data into it (Edit -> Edit Mode, Edit -> Paste). Then select Mode -> FAT/FAT32/NTFS Boot Record and Edit -> Export to Text File. Of course you would discard changes on exit (DMDE prompts you to Write or Discard). The procedure would be safer (and longer) if you were to write the data to a BIN file using a hex editor (eg HxD), and then view the file in DMDE. |
| Author: | Spotmen [ December 22nd, 2020, 5:49 ] |
Thank you for sharing |
