| Flash formatted but notmatter. http://forum.hddguru.com/viewtopic.php?f=10&t=40389 |
Page 1 of 1 |
| Author: | hack3rcon [ September 15th, 2020, 1:57 ] |
| Post subject: | Flash formatted but notmatter. |
Hello, I have a SP USB Drive 8GB and when I plug it to my system then no drive mounted. I tried some tools like "wipe", "dd" and "HDDLLF". All of them wiped the drive but not matter. No partition created or... These are some information: Code: # mkfs.ext4 /dev/sdc mke2fs 1.44.5 (15-Dec-2018) Warning: could not erase sector 2: Input/output error Creating filesystem with 1890624 4k blocks and 473280 inodes Filesystem UUID: 6952ec20-6c05-4fbe-9553-a0d508ded56c Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632 Allocating group tables: done Warning: could not read block 0: Input/output error Warning: could not erase sector 0: Input/output error Writing inode tables: done Creating journal (16384 blocks): done Writing superblocks and filesystem accounting information: 0/58 And: Code: # dmesg [90046.173852] print_req_error: I/O error, dev sdc, sector 0 [90046.173857] Buffer I/O error on dev sdc, logical block 0, async page read I used the SP format utility too but... Any way to fix this drive? Thank you. |
| Author: | HaQue [ September 15th, 2020, 3:56 ] |
| Post subject: | Re: Flash formatted but notmatter. |
drive is faulty |
| Author: | hack3rcon [ September 15th, 2020, 4:30 ] |
HaQue wrote: drive is faulty Any idea to format it? |
| Author: | Arch Stanton [ September 15th, 2020, 6:24 ] |
Do you need the data? If so then it's the wrong approach. If not then it's not worth it, get a new one. |
| Author: | HaQue [ September 15th, 2020, 23:47 ] |
hack3rcon wrote: HaQue wrote: drive is faulty Any idea to format it? It is like trying to fix a broken car by giving it a really good clean. It is still broken |
