 Post subject: Flash formatted but notmatter.
PostPosted: September 15th, 2020, 1:57
I have a SP USB Drive 8GB and when I plug it to my system then no drive mounted. I tried some tools like "wipe", "dd" and "HDDLLF". All of them wiped the drive but not matter. No partition created or...
These are some information:
# mkfs.ext4 /dev/sdc
mke2fs 1.44.5 (15-Dec-2018)
Warning: could not erase sector 2: Input/output error
Creating filesystem with 1890624 4k blocks and 473280 inodes
Filesystem UUID: 6952ec20-6c05-4fbe-9553-a0d508ded56c
Superblock backups stored on blocks:
   32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
Allocating group tables: done
Warning: could not read block 0: Input/output error
Warning: could not erase sector 0: Input/output error
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information:  0/58
And:
# dmesg
[90046.173852] print_req_error: I/O error, dev sdc, sector 0
[90046.173857] Buffer I/O error on dev sdc, logical block 0, async page read
I used the SP format utility too but...
Any way to fix this drive?
Thank you.
 Post subject: Re: Flash formatted but notmatter.
PostPosted: September 15th, 2020, 3:56
drive is faulty
PostPosted: September 15th, 2020, 4:30
HaQue wrote:
drive is faulty
Any idea to format it?
PostPosted: September 15th, 2020, 6:24
Do you need the data? If so then it's the wrong approach. If not then it's not worth it, get a new one.
PostPosted: September 15th, 2020, 23:47
hack3rcon wrote:
HaQue wrote:
drive is faulty
It is like trying to fix a broken car by giving it a really good clean. It is still broken
