 Post subject: M2-drive fails to be read
PostPosted: October 23rd, 2020, 7:45
A customer brought me this drive which I cannot figure out the root-cause on. Attaching the drive gives me this in syslog:
Oct 23 13:40:10 dr kernel: [  567.000141] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Oct 23 13:40:10 dr kernel: [  567.000557] ata1.00: ATA-10: SAMSUNG MZNLN256HMHQ-000H1, MAV21H3Q, max UDMA/100
Oct 23 13:40:10 dr kernel: [  567.000563] ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Oct 23 13:40:10 dr kernel: [  567.000983] ata1.00: configured for UDMA/100
Oct 23 13:40:10 dr kernel: [  567.000990] ata1: EH complete
Oct 23 13:40:10 dr kernel: [  567.001135] scsi 0:0:0:0: Direct-Access     ATA      SAMSUNG MZNLN256 MAV2 PQ: 0 ANSI: 5
Oct 23 13:40:10 dr kernel: [  567.001385] sd 0:0:0:0: Attached scsi generic sg1 type 0
Oct 23 13:40:10 dr kernel: [  567.001394] sd 0:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB)
Oct 23 13:40:10 dr kernel: [  567.001399] sd 0:0:0:0: [sdb] 4096-byte physical blocks
Oct 23 13:40:10 dr kernel: [  567.001535] sd 0:0:0:0: [sdb] Write Protect is off
Oct 23 13:40:10 dr kernel: [  567.001580] sd 0:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Oct 23 13:40:41 dr kernel: [  597.824202] ata1: hard resetting link
Oct 23 13:40:51 dr kernel: [  607.836142] ata1: hard resetting link
Oct 23 13:41:01 dr kernel: [  617.848116] ata1: hard resetting link
Oct 23 13:41:11 dr kernel: [  628.420141] ata1: link is slow to respond, please be patient (ready=0)
Oct 23 13:41:36 dr kernel: [  652.892150] ata1: limiting SATA link speed to 1.5 Gbps
Oct 23 13:41:36 dr kernel: [  652.892153] ata1: hard resetting link
Oct 23 13:41:41 dr kernel: [  658.080152] ata1.00: disabled
Oct 23 13:41:41 dr kernel: [  658.080158] ata1.00: device reported invalid CHS sector 0
Oct 23 13:41:41 dr kernel: [  658.080168] ata1: EH complete
Oct 23 13:41:41 dr kernel: [  658.080208] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080212] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080218] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080232] quiet_error: 4 callbacks suppressed
Oct 23 13:41:41 dr kernel: [  658.080274] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080277] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080281] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080350] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080353] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080357] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080409] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080411] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080415] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080449] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080452] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080455] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080493] ldm_validate_partition_table(): Disk read failed.
Oct 23 13:41:41 dr kernel: [  658.080508] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080510] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080513] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080547] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080549] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080552] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080602] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080604] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080607] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080640] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080642] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080646] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080683] Dev sdb: unable to read RDB block 0
Oct 23 13:41:41 dr kernel: [  658.080698] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080700] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080703] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080737] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080739] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080742] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080792] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080794] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080798] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080825] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080828] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080831] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080878] sd 0:0:0:0: [sdb] Unhandled error code
Oct 23 13:41:41 dr kernel: [  658.080880] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.080884] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00
Oct 23 13:41:41 dr kernel: [  658.080902]  sdb: unable to read partition table
Oct 23 13:41:41 dr kernel: [  658.081051] sd 0:0:0:0: [sdb] READ CAPACITY(16) failed
Oct 23 13:41:41 dr kernel: [  658.081054] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.081057] sd 0:0:0:0: [sdb] Sense not available.
Oct 23 13:41:41 dr kernel: [  658.081110] sd 0:0:0:0: [sdb] READ CAPACITY failed
Oct 23 13:41:41 dr kernel: [  658.081112] sd 0:0:0:0: [sdb]  Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
Oct 23 13:41:41 dr kernel: [  658.081115] sd 0:0:0:0: [sdb] Sense not available.
Oct 23 13:41:41 dr kernel: [  658.081236] sd 0:0:0:0: [sdb] Truncating mode parameter data from 12148 to 512 bytes
Oct 23 13:41:41 dr kernel: [  658.081260] sd 0:0:0:0: [sdb] Attached SCSI disk
I will have to tell the customer to contact Kroll because this is out of my league, but I'm still curious; is this a controller issue or a NAND-issue? Because I see that the drive can be identified correctly, which gives me the idea that the controller is working to a degree, but when trying to read CHS 0 everything goes bork, which tells me atleast one of the two NANDs are screwed.
 Post subject: Re: M2-drive fails to be read
PostPosted: October 23rd, 2020, 12:11
It is more of a translator issue, most of the time. Unfortunately, I don't believe it is a model supported by PC3000 and therefore not recoverable by most labs. I'd be surprised if Kroll can handle it, either. If I were you, I'd be looking for someone who has a way to work with the translator of this model of Samsung SSD and refer your client to them.
Users browsing this forum: Google [Bot] and 14 guests
