| M2-drive fails to be read http://forum.hddguru.com/viewtopic.php?f=10&t=40515 |
Page 1 of 1 |
| Author: | bos [ October 23rd, 2020, 7:45 ] |
| Post subject: | M2-drive fails to be read |
A customer brought me this drive which I cannot figure out the root-cause on. Attaching the drive gives me this in syslog: Code: Oct 23 13:40:10 dr kernel: [ 567.000141] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) Oct 23 13:40:10 dr kernel: [ 567.000557] ata1.00: ATA-10: SAMSUNG MZNLN256HMHQ-000H1, MAV21H3Q, max UDMA/100 Oct 23 13:40:10 dr kernel: [ 567.000563] ata1.00: 500118192 sectors, multi 16: LBA48 NCQ (depth 31/32), AA Oct 23 13:40:10 dr kernel: [ 567.000983] ata1.00: configured for UDMA/100 Oct 23 13:40:10 dr kernel: [ 567.000990] ata1: EH complete Oct 23 13:40:10 dr kernel: [ 567.001135] scsi 0:0:0:0: Direct-Access ATA SAMSUNG MZNLN256 MAV2 PQ: 0 ANSI: 5 Oct 23 13:40:10 dr kernel: [ 567.001385] sd 0:0:0:0: Attached scsi generic sg1 type 0 Oct 23 13:40:10 dr kernel: [ 567.001394] sd 0:0:0:0: [sdb] 500118192 512-byte logical blocks: (256 GB/238 GiB) Oct 23 13:40:10 dr kernel: [ 567.001399] sd 0:0:0:0: [sdb] 4096-byte physical blocks Oct 23 13:40:10 dr kernel: [ 567.001535] sd 0:0:0:0: [sdb] Write Protect is off Oct 23 13:40:10 dr kernel: [ 567.001580] sd 0:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Oct 23 13:40:41 dr kernel: [ 597.824202] ata1: hard resetting link Oct 23 13:40:51 dr kernel: [ 607.836142] ata1: hard resetting link Oct 23 13:41:01 dr kernel: [ 617.848116] ata1: hard resetting link Oct 23 13:41:11 dr kernel: [ 628.420141] ata1: link is slow to respond, please be patient (ready=0) Oct 23 13:41:36 dr kernel: [ 652.892150] ata1: limiting SATA link speed to 1.5 Gbps Oct 23 13:41:36 dr kernel: [ 652.892153] ata1: hard resetting link Oct 23 13:41:41 dr kernel: [ 658.080152] ata1.00: disabled Oct 23 13:41:41 dr kernel: [ 658.080158] ata1.00: device reported invalid CHS sector 0 Oct 23 13:41:41 dr kernel: [ 658.080168] ata1: EH complete Oct 23 13:41:41 dr kernel: [ 658.080208] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080212] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080218] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080232] quiet_error: 4 callbacks suppressed Oct 23 13:41:41 dr kernel: [ 658.080274] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080277] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080281] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080350] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080353] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080357] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080409] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080411] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080415] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080449] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080452] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080455] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080493] ldm_validate_partition_table(): Disk read failed. Oct 23 13:41:41 dr kernel: [ 658.080508] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080510] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080513] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080547] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080549] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080552] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080602] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080604] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080607] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080640] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080642] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080646] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080683] Dev sdb: unable to read RDB block 0 Oct 23 13:41:41 dr kernel: [ 658.080698] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080700] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080703] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080737] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080739] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080742] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080792] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080794] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080798] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080825] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080828] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080831] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 18 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080878] sd 0:0:0:0: [sdb] Unhandled error code Oct 23 13:41:41 dr kernel: [ 658.080880] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.080884] sd 0:0:0:0: [sdb] CDB: Read(10): 28 00 00 00 00 00 00 00 08 00 Oct 23 13:41:41 dr kernel: [ 658.080902] sdb: unable to read partition table Oct 23 13:41:41 dr kernel: [ 658.081051] sd 0:0:0:0: [sdb] READ CAPACITY(16) failed Oct 23 13:41:41 dr kernel: [ 658.081054] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.081057] sd 0:0:0:0: [sdb] Sense not available. Oct 23 13:41:41 dr kernel: [ 658.081110] sd 0:0:0:0: [sdb] READ CAPACITY failed Oct 23 13:41:41 dr kernel: [ 658.081112] sd 0:0:0:0: [sdb] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK Oct 23 13:41:41 dr kernel: [ 658.081115] sd 0:0:0:0: [sdb] Sense not available. Oct 23 13:41:41 dr kernel: [ 658.081236] sd 0:0:0:0: [sdb] Truncating mode parameter data from 12148 to 512 bytes Oct 23 13:41:41 dr kernel: [ 658.081260] sd 0:0:0:0: [sdb] Attached SCSI disk I will have to tell the customer to contact Kroll because this is out of my league, but I'm still curious; is this a controller issue or a NAND-issue? Because I see that the drive can be identified correctly, which gives me the idea that the controller is working to a degree, but when trying to read CHS 0 everything goes bork, which tells me atleast one of the two NANDs are screwed. |
| Author: | lcoughey [ October 23rd, 2020, 12:11 ] |
| Post subject: | Re: M2-drive fails to be read |
It is more of a translator issue, most of the time. Unfortunately, I don't believe it is a model supported by PC3000 and therefore not recoverable by most labs. I'd be surprised if Kroll can handle it, either. If I were you, I'd be looking for someone who has a way to work with the translator of this model of Samsung SSD and refer your client to them. |
