 Post subject: Crucial MX300 SSD CT525MX300SSD1 - No ID - always BSY
PostPosted: October 29th, 2020, 11:57
I got a MX300 SSD CT525MX300SSD1 that doesn' t ID. Always BSY. I tried cold and hot, when connected to PC3K, it's always BSY. Controller is Marvell 88SS1074.
I've search on this forum and google, nothing really help me, someone suggest rebailling.
Sam
 Post subject: Re: Crucial MX300 SSD CT525MX300SSD1 - No ID - always BSY
PostPosted: October 29th, 2020, 12:44
Do you have PC3000 SSD? Did connect terminal and jumper for safe mode? Try the WD utility?
PostPosted: October 30th, 2020, 8:54
Thank you for your relpy. Yes, I do have PC3K SSD. I've compare Crucial PCB with WD but I can't find where are RX & TX. I've google it, so far no luck. Do you have an idea ? There's 4 holes near the conroller chip, maybe that could be for JTAG ?
PostPosted: October 30th, 2020, 10:33
In this SSD, the introduction of technical commands for ATA and the terminal is blocked
PostPosted: October 30th, 2020, 10:40
terminal
PostPosted: October 30th, 2020, 10:43
Put jumpers
PostPosted: October 30th, 2020, 11:11
Thank you. I've connect terminal but if you are saying it's locked, is there anyhting we can do ?
I tried WD Utility in PC3K, nothing so far.
PostPosted: October 30th, 2020, 11:12
ok, let me put the jumper. thanks
PostPosted: October 30th, 2020, 11:44
jumpers
PostPosted: October 30th, 2020, 12:21
Thank you very much for those detailed information.
I've put the two jumper. I connected terminal. I see rx-tx flashing but I don't get much more.
PostPosted: October 30th, 2020, 13:30
immediately after switching on, enter the command: ser on
PostPosted: November 3rd, 2020, 8:36
Excuse me for the delay, I am sick, I ll try ASAP
PostPosted: November 10th, 2020, 6:43
With the great help of gold, I got access to terminal however story continue as I keep getting same message "Authentication fail"
It looks like "authentication" is enabled but I can't find how to bypass or authenticate.
SER ON
Get temp 00000021
??? cmd
:REL
Authentication fail
??? cmd
:SATA
Authentication fail
??? cmd
:CMDLOG
CMDLOG: No ATA/SATA command found.
:GETRC
Authentication fail
??? cmd
:G
Authentication fail
??? cmd
:GETPM
Authentication fail
??? cmd
:SHOWCMD ON
Authentication fail
??? cmd
:VER
BootLoader Ver:
$Rev: 49e66c9 $
$URL: ssh://git@stash.micron.com:7999/ssdfw/acadia.git master $
Firmware Ver:
Compiled: Aug 16 2016 02:37:30
49e66c9
Internal Version: M700MCR003BC0532
External Version: M0CR031
CompilingCfg:DEAN_B0KB_RAIN_DPP_SIGN_REL
TCG Table Ver: 000A.000
CUSTOMER:0, PROD:E8
Rain Cfg: 44:1
User Capacity: 525G, DEAN, REV_NUM = DEAN2.1
SVN Info:
$Rev: 49e66c9 $
$URL: ssh://git@stash.micron.com:7999/ssdfw/acadia.git release/FW514_Hotfix $
Authentication enabled
MSP430 Firmware Ver:
Rev: 197
Manu Data:
Module Number(ASCII): Crucial_CT525MX300SSD1
Serial Number(ASCII): 164514990B06
PSID(ASCII): 5825C7461C4C0821E100000089C981F0
WWN(HEX): 0000500A 00000751
WWNX(HEX): 00000000 00000000
Hardware configuration in Manu Data:
NAND: B0KB SDP*0 DDP*1 QDP*0 8DP*0 16DP*0 528GB capacity
Randomizer: SOC Scrambler, ROM LUT
Extended Blocks ENABLED
DRAM: 2E0F 1 512MB capacity
SOC: DEAN2.1 25MHz clock
PCB: 2089A
:HW
Authentication fail
??? cmd
:SVER
Authentication fail
??? cmd
PostPosted: March 15th, 2022, 15:44
I am working on a SanDisk Ultra with Marvell 88SS1074 controller, gets RDY, but then goes to BSY.
It is a 3D NAND model SSD and PC3KSSD says the chip is not in the database.
Is it true?
PostPosted: March 16th, 2022, 5:14
I88SS1074 is listed
https://blog.acelaboratory.com/pc-3000- ... dated.html
PostPosted: March 16th, 2022, 6:49
Right, the controller is, thanks.
The question refers to the 3D NAND being supported.
PostPosted: March 16th, 2022, 7:09
The chip database is available from the main menu or ctrl z - 45489AB aren't listed in mine either - worth confirming with ACE though.
Users browsing this forum: No registered users and 42 guests
