With the great help of gold, I got access to terminal however story continue as I keep getting same message "Authentication fail"
It looks like "authentication" is enabled but I can't find how to bypass or authenticate.
SER ON
Get temp 00000021
??? cmd
:REL
Authentication fail
??? cmd
:SATA
Authentication fail
??? cmd
:CMDLOG
CMDLOG: No ATA/SATA command found.
:GETRC
Authentication fail
??? cmd
:G
Authentication fail
??? cmd
:GETPM
Authentication fail
??? cmd
:SHOWCMD ON
Authentication fail
??? cmd
:VER
BootLoader Ver:
$Rev: 49e66c9 $
$URL:
ssh://git@stash.micron.com:7999/ssdfw/acadia.git master $
Firmware Ver:
Compiled: Aug 16 2016 02:37:30
49e66c9
Internal Version: M700MCR003BC0532
External Version: M0CR031
CompilingCfg:DEAN_B0KB_RAIN_DPP_SIGN_REL
TCG Table Ver: 000A.000
CUSTOMER:0, PROD:E8
Rain Cfg: 44:1
User Capacity: 525G, DEAN, REV_NUM = DEAN2.1
SVN Info:
$Rev: 49e66c9 $
$URL:
ssh://git@stash.micron.com:7999/ssdfw/acadia.git release/FW514_Hotfix $
Authentication enabledMSP430 Firmware Ver:
Rev: 197
Manu Data:
Module Number(ASCII): Crucial_CT525MX300SSD1
Serial Number(ASCII): 164514990B06
PSID(ASCII): 5825C7461C4C0821E100000089C981F0
WWN(HEX): 0000500A 00000751
WWNX(HEX): 00000000 00000000
Hardware configuration in Manu Data:
NAND: B0KB SDP*0 DDP*1 QDP*0 8DP*0 16DP*0 528GB capacity
Randomizer: SOC Scrambler, ROM LUT
Extended Blocks ENABLED
DRAM: 2E0F 1 512MB capacity
SOC: DEAN2.1 25MHz clock
PCB: 2089A
:HW
Authentication fail
??? cmd
:SVER
Authentication fail
??? cmd
