 Post subject: NAND Dumps - Digital Voice Recorders
PostPosted: November 13th, 2020, 10:13
I am looking if someone could share few NAND dumps with me so that i can do some research on them , Old models , new models anything please
 Post subject: Re: NAND Dumps - Digital Voice Recorders
PostPosted: November 14th, 2020, 5:16
If I remember correctly most of these are encoded with proprietary audio codecs, even if you get the data from the nand you're not going to be able to get anything useful from that data.
PostPosted: November 15th, 2020, 8:28
Still,
If i can get a few dumps ....
PostPosted: November 15th, 2020, 13:26
You can buy donors. Its standard procedure. I think nobody will give you client dumps.
PostPosted: November 15th, 2020, 23:01
Aha ,
So Nobody buys donors there are all clients dumps :shock: ,Can you suggest some brands to play around with
PostPosted: November 16th, 2020, 10:04
Try Olympus and Panasonic.
PostPosted: November 16th, 2020, 13:08
Thanks Bossie ,
I Appreciate You advice .
PostPosted: November 16th, 2020, 13:18
I have had a couple of Panasonic VR's in over the years and from what I remember they were both eMMC. The last one I had was for deleted files and as @Lardman says they have proprietary codecs and the data was not recoverable. I even spoke to TS here in the US who in turn spoke to Olympus HO in Japan and they would not release any information about how the codecs work.
PostPosted: November 17th, 2020, 4:05
"Its standard procedure"
we all buy donors to test
PostPosted: November 17th, 2020, 4:42
also try searching on SC for voice recorder to see the type of stuff seen in the wild, and what they present to you
https://www.google.com/search?as_sitesearch=flash-extractor.com&q=voice+recorder
Users browsing this forum: Ahmed Saeed and 141 guests
