NAND Dumps - Digital Voice Recorders
Posted: November 13th, 2020, 10:13
by Amarbir[CDR-Labs]
I am looking if someone could share few NAND dumps with me so that i can do some research on them , Old models , new models anything please
Re: NAND Dumps - Digital Voice Recorders
Posted: November 14th, 2020, 5:16
by Lardman
If I remember correctly most of these are encoded with proprietary audio codecs, even if you get the data from the nand you're not going to be able to get anything useful from that data.
Posted: November 15th, 2020, 8:28
Lardman wrote:If I remember correctly most of these are encoded with proprietary audio codecs, even if you get the data from the nand you're not going to be able to get anything useful from that data.
Still,
If i can get a few dumps ....
Posted: November 15th, 2020, 13:26
by arvika
You can buy donors. Its standard procedure. I think nobody will give you client dumps.
Posted: November 15th, 2020, 23:01
arvika wrote:You can buy donors. Its standard procedure. I think nobody will give you client dumps.
Aha ,
So Nobody buys donors there are all clients dumps
,Can you suggest some brands to play around with
Posted: November 16th, 2020, 10:04
by arvika
Try Olympus and Panasonic.
Posted: November 16th, 2020, 13:08
arvika wrote:Try Olympus and Panasonic.
Thanks Bossie ,
I Appreciate You advice .
Posted: November 16th, 2020, 13:18
by ddrecovery
I have had a couple of Panasonic VR's in over the years and from what I remember they were both eMMC. The last one I had was for deleted files and as @Lardman says they have proprietary codecs and the data was not recoverable. I even spoke to TS here in the US who in turn spoke to Olympus HO in Japan and they would not release any information about how the codecs work.
Posted: November 17th, 2020, 4:05
by HaQue
"Its standard procedure"
we all buy donors to test
Posted: November 17th, 2020, 4:42
by HaQue
also try searching on SC for voice recorder to see the type of stuff seen in the wild, and what they present to you
https://www.google.com/search?as_sitesearch=flash-extractor.com&q=voice+recorder
