| SSD plugged and unplugged frequently. http://forum.hddguru.com/viewtopic.php?f=10&t=40609 |
Page 1 of 1 |
| Author: | hack3rcon [ November 16th, 2020, 13:15 ] |
| Post subject: | SSD plugged and unplugged frequently. |
Hello, I have a 120GB SSD and I just copied some files on it and unplugged it from my PC, after some years, when I plugged it to my PC then Windows OS can't detect my SSD and on Linux OS it plugged and unplugged frequently. Why? I never used this SSD. When I used "cfdisk" to remove all partitions on it then it show me: Code: Failed to write disklabel. And log tell me: Code: $ sudo dmesg [17020.700937] Buffer I/O error on dev sdc, logical block 29305184, async page read [17024.159216] Buffer I/O error on dev sdc, logical block 29305184, async page read What is the SSD problem? Thank you. |
| Author: | pclab [ November 16th, 2020, 15:31 ] |
| Post subject: | Re: SSD plugged and unplugged frequently. |
There are some cases already studied that the SSD when unpowered could suffer from data retention problems. Crucial explains it here: https://www.crucial.com/support/article ... smart-data "The Joint Electron Device Engineering Council (JEDEC) is the industry group which creates standards and specifications for semiconductor-based devices and assemblies. Micron is a leading member of JEDEC, which defines data retention in a specific way: For SSDs in client applications (like business or personal computers), data retention for an SSD shall be one year, in an unpowered state, stored at 30 °C (86 °F). This should give most computer users plenty of time to retrieve any data from an unused drive after some time on the shelf, if needed." So, it could be that or it could be that the SSD was not very well stored (magnetic fields for instance...) |
