Winbond W25N01GV Off chip ECC
Posted: January 12th, 2021, 14:55
Hi there
I've been looking at an off chip read of a Winbond W25N01GV SPI NAND 128Mb chip for a few days. (yes my life is that exciting).
It's from an IP Camera, and I'm looking to extract an lzma file from the first partition around 0x9300 of the dump. This contains the proper bootloader I need to further research.
I've removed the OOB (the layout of which is weird below), but when trying to decompress the lzma file it is clearly corrupted, and fails after producing only a little valid data.
Comparison with a dump from the same camera with the same bootloader version shows 420 bit errors between them for the data area I am interested in.
I do not have access to either device - just the dumps.
I did write a program to navigate these 420 bits errors that allowed me to interactively try both options for each of the 420 bits the 2 dumps disagreed on, previewing the decompression results, and backtracking to earlier choices as needed. That's allowed me to get about 200 bits in with valid results but now I'm struggling to make further progress.
I did look at using the ECC data in the dump to correct the bits, but short of spending $1000s for VNR there don't seem to be many tools that understand either the OOB layout or the ECC scheme used.
Page: 2048 + 64 OOB
OOB layout:
0x00 - 0x40F user data
0x410 - 0x40D 14 bytes (assumed ECC1)
0x40E - 0x7FF user data
0x800 - 0x801 Bad block marker (0xFF 0xFF)
0x802 - 0x80F user data
0x810 - 0x81D 14 bytes (assumed ECC2)
0x81E - 0x83F 0xFFs (except 0x83A there are always 2 0x00s)
So 0x800 user data in all and 0x40 OOB
On a blank page
ECC1 is always 0A 3A E9 39 43 DE 09 AC 83 22 D0 E1 7F F3
ECC2 is always A5 BB 1D F0 B8 A2 03 70 69 78 36 69 84 B1
So I'm thinking BCH-8 with a sector size of 1024 each having it's own 14 byte ECC code. 2 sectors in each 2048 + 64 page.
Despite this, the bootlog shows:
From bootlog of the kernel:
[ 1.602149] SPI Nand(cs 0) ID: 0xef 0xaa 0x21
[ 1.606622] nand: device found, Manufacturer ID: 0xef, Chip ID: 0xaa
[ 1.612980] nand: Winbond W25N01GV
[ 1.616460] nand: 128MiB, SLC, page size: 2048
[ 1.620901] Nand(Auto): OOB:64B ECC:4bit/512
The last line of this seems to disagree with my guess above, but it that because I'm looking at a physical off chip dump rather than the logical OOB view the OS gets? Data sheets on manufacturer web just talk about the logical layout view not what a chip reader sees.
Can anyone recommend a sensible way forward? Especially tools where I just press a button and magic happens lol :p
I know going too deep into BCH will get very mathematically complex likely beyond my ability for what is just a fun project for me. I can try different schemes, rearrange the OOB areas of the dump in to 1 64 byte area, try different polys for example, but if I need to work at a university and smoke a pipe with a whiteboard in the background I might give up
Any help appreciated.
Page: 2048 + 64 OOB
OOB layout:
On a blank page
