| transcend TS240GESD230C USB-C SSD http://forum.hddguru.com/viewtopic.php?f=10&t=40826 |
Page 1 of 1 |
| Author: | fzabkar [ January 13th, 2021, 15:52 ] |
| Post subject: | Re: transcend TS240GESD230C USB-C SSD |
You can check the voltages at L8 - L11, and L1 and L4. If you need to bypass the bridge, you can remove capacitors C76 - 79 and make your external SATA connections there. The "ROM mode" shorting points would be either J4 or J5 (J5 looks safe to try). |
| Author: | Spotmen [ January 13th, 2021, 16:20 ] |
Thank you so much. I'll give it a try tomorrow, it's little bit late for today. I'll keep you posted. |
| Author: | samstown [ January 18th, 2021, 4:54 ] |
fzabkar wrote: You can check the voltages at L8 - L11, and L1 and L4. If you need to bypass the bridge, you can remove capacitors C76 - 79 and make your external SATA connections there. The "ROM mode" shorting points would be either J4 or J5 (J5 looks safe to try). This is what I measure. What are those L ? L1 = 1.069 L4 = 1.181 L8 = 1.886 L9 = 3.998 L10 = 1.905 L11 = 3.339 |
| Author: | fzabkar [ January 18th, 2021, 14:27 ] |
The "L" components are inductors. They form part of a DC-DC converter which converts the +5V supply to lower voltages for the main ICs.
L4 = Vcore for SM2258XT controller L11 = 3.3V supply for NANDs ? L9 (4V) looks out of place, but I don't know what it could be used for. |
