| MARVELL 88ss9183-bnp2 http://forum.hddguru.com/viewtopic.php?f=10&t=41087 |
Page 1 of 1 |
| Author: | sempre [ March 18th, 2021, 7:05 ] |
| Post subject: | Re: MARVELL 88ss9183-bnp2 |
Please infos for adapter usb?? |
| Author: | Lardman [ March 18th, 2021, 7:21 ] |
Could try some of these. https://forum.hddguru.com/viewtopic.php?f=1&t=40821 Probably needs PC3000 portable As Roman has said. What's getting hot? |
| Author: | sempre [ March 18th, 2021, 10:34 ] |
Lardman wrote: Could try some of these. https://forum.hddguru.com/viewtopic.php?f=1&t=40821 Probably needs PC3000 portable As Roman has said. What's getting hot? Is processor Marvell Thanks reply! |
| Author: | Lardman [ March 18th, 2021, 14:17 ] |
Is it shorted or just getting generally hot ? I put a usb meter inline to get an idea of current drawn. You could try a heat sink / fan or freeze spray and something like hddsuperclone if DE is being a pain but I'm afraid I've had no luck with them at all. Hopefully some of our more seasoned veterans may share some secrets |
| Author: | fzabkar [ March 18th, 2021, 15:19 ] |
There are 3 switchmode regulators (ODH + ODH + SBN) and one LDO linear regulator (marking "3XT"). Measure the resistance between ground and the output of each regulator. Also measure the resistance between ground and the +3.3V input. |
